? for computer gurus
  Printable Version
Honda Accord >> General >> Off Topic >> ? for computer gurus Page: [1] 2   next >   >>
Login
? for computer gurus - 10/23/2007 8:08:37 AM
00AccordLX5spd
Status: offline
Ever since I bought my home computer (Cheap Dell, only CD drive, basic functionality) there are a ton of programs that automatically launch on startup making it run as slow as Christmas.  For example: McAffee is always asking me to update, Norton Ghost always pops up, and there are about 8 little icons at the bottom right of my screen on the toolbar.  Most are things I do not use, and many pop up periodically bugging me asking me to "update" something.  How do I get rid of all of this garbage?  Do I just uninstall the programs?  I'm not too experienced with Windows XP.  I just got it at work (I was the last in the building to install it on my machine).  So now I have it at work and at home.  I liked Windows 2000 better (probably simply because I was used to it)
< Message edited by 00AccordLX5spd -- 10/23/2007 8:11:16 AM >
_____________________________
2000 Accord LX Sedan F23A1 5spd
-Short Shift Adapter
-eBay SRI w/ K&N
1995 Accord V6 Sedan AT - AKA "the money pit"
1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
Post #: 1
RE: ? for computer gurus - 10/23/2007 9:17:37 AM
Fenix
Status: offline
Fenix's photo gallery
blech windows 2K almost as bad as windows ME. onto your question you can uninstal using the control panel, then "add or remove programs" you should see the programs you dont want listed in there. if not found in there then there should be an uninstal file located somewhere in the respective folder. If you decide that you want to keep the proggies then just right click on the icons in the task bar and go to options. im not familar with the progs your using, but when you right click there should be an option for options/prefrences. in there you should be able to disable them from start up. finally there is a way to disable them from starting up when you boot your OS. for some reason i am at a loss for how to do it, strange thing is i did it the other day. when i get to my home comp ill figure out how to do it, and post here. if someone hasnt already done it by then.
Arent computers FUN!!
04 EX 4cyl 5AT Coupe
Fujita CAI
Custom Heads & TYC Tails
Apexi WS2 Cat Back Exhaust
Front Grill
Interior LED rods(7color)
20% Tint
TSX Intake Manifold
DC Ceramic Header
Ralco Light Weight Pullies(In Hand)
TL-s Front Sway Bar
(in reply to 00AccordLX5spd)
Post #: 2
RE: ? for computer gurus - 10/23/2007 9:26:26 AM
sir_nasty
Status: offline
3 Step Process:
1) Remove Crappy Programs
go to start, control panel, add/remove programs and un-install crap that you don't want or that is trial periods.  It's usually safest to remove one program at a time then restart the computer but that is also the slow way.  Only un-install stuff that you see pop-up etc and don't want.  Once you have all that done.
2) Optimize Performance (basic)
Right click on the desktop, go to properties, in the Theme box select "windows classic" (unless you really are attached to the fancy xp junk).  Next right click my computer, properties, Advanced Tab, Top box "performance" click settings, choose "Adjust for best performance", that will free up un-neccessary pretty crap.
3) Optimize Start-up
Now, click on start, run, type in "msconfig" (without the ""), hit enter, click on the tab labeled "startup", put your cursor over the | to the right of "command" in that window.  It will change to an arrowed cursor, expand that column so you can see what the "command line" for it is,  Now go through and un-check everything that has the word dell in it, uncheck all the other stuff that's in there that you don't like, if you don't know what it is leave it alone (igfxtray, hkcmd, igfxpers, jusched, ctfmon, lgbpd: leave those checked), click ok, restart the computer, it will pop-up a box about running in selective startup, check the box that says "don't show this again" and click ok,
Those 3 things will make a world of difference, if you uncheck something and suddenly your e-mail reminder or something like that stops working then go back in to msconfig and re-check whatever it is you still wanted.
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Post #: 3
RE: ? for computer gurus - 10/23/2007 11:19:19 AM
thunder_x
Status: offline
thunder_x's photo gallery
if i were you, i would clean out the entire hard drive so it could start fresh again (reformating)
i have a dell too, and what i do is...
you get a windows xp cd (home edition or professional)
pop it in, dont install it when it asks you
restart the comp, press f2 to go into the bootup menu, then change the boot sequence so that the cd drive boots first
then exit and save the settings
then it will take you into a blue screen thing, and start loading all the crap from the cd
after it's done with that, you delete the partition and install windows xp
then you're done with a fresh new comp, but you will lose all your files, so save them on a flash drive or something
it sounds complicated but it's really not, eaiser than installing my AEM short ram intake!
http://www.metrocast.net/~dragontears/reformat.html
the link says to create a new partition, i dont know what difference this makes, cause i never do that when i reformat. i just install windows xp after deleting the existing partition
Project 91 ACCORD-193k miles
All-Motor F22A1
cb7tunercom/vbb/showthread.php?t=108490
(in reply to sir_nasty)
Post #: 4
RE: ? for computer gurus - 10/23/2007 11:26:05 AM
00AccordLX5spd
Status: offline
Nice responses.  thanks guys!  I'll print this out and do as told.  I hate all those stuprid trial period garbage programs.  I guess Dell gets paid by all those companies to put that garbage on their computers.
Here's one more:
My dad's computer at his house (my former computer from college) has this terrible thing that happens in his web browser.  About 50% of the time you click on something, it automatically does a search for afilliatetarget.com.  Sometimes if I am on his computer and I even click on a thread on this site, it pulls that crap.  Has anyone ever heard of this?
-eBay SRI w/ K&N
Post #: 5
RE: ? for computer gurus - 10/23/2007 12:27:05 PM
sir_nasty
Status: offline
malware/spyware look here
http://www.pctools.com/mrc/infections/id/AffiliateTarget/
Or download Lavasoft Ad-Aware SE Personal (free) and use it to remove the spyware/adware on the system
Post #: 6
RE: ? for computer gurus - 10/23/2007 12:31:19 PM
00AccordLX5spd
Status: offline
Cool, thanks.  Spybot won't ever remove that one.  Nor am I aware if it even recognizes it.  I need to download adaware.  Thanks for the link!
-eBay SRI w/ K&N
Post #: 7
RE: ? for computer gurus - 10/23/2007 12:45:27 PM
sir_nasty
Status: offline
no problem, I've fought with a TON of that crap when I was doing repair...
Post #: 8
RE: ? for computer gurus - 10/23/2007 2:03:45 PM
thunder_x
Status: offline
reformat it, it's the easiest way to get rid of all the junk on your computer, and it will have your computer running like a new one again, faster too!
All-Motor F22A1
Post #: 9
RE: ? for computer gurus - 10/23/2007 4:03:27 PM
superballz00
Status: offline
Check out Blackviper. http://www.blackviper.com/WinXP/servicecfg.htm
Disabling those services really makes the pc boot up and run faster. Also some of the program might still lauch even if you disable them in msconfig but if you do it in services.msc they won't start up at all.
97 accord LX coupe A/T 97K miles
(in reply to thunder_x)
Post #: 10
RE: ? for computer gurus - 10/23/2007 4:07:04 PM
Trav20
Status: offline
Trav20's photo gallery
UPDATE!! UPDATE!! UPDATE!!
I cannot stress this enough. You must update your virus protection as soon as it comes out no matter how annoying the pop up things are. New viruses are made everyday by people who don't have lives and have enough time on their hands to make programs that will destroy your computer. I have made the same mistake before and its not pretty when the virus deletes essential programs/files like the ones in the system(the files that actually enable your computer to work).
A facelift to an already cool car!
http://www.cardomain.com/ride/2482364
Check it out guys!
Post #: 11
RE: ? for computer gurus - 10/23/2007 4:17:45 PM
sir_nasty
Status: offline
quote:
ORIGINAL: superballz00
Under msconfig you can disable services as well if need be, but if you do that without knowing what you are doing there is the potential for massive issues.Very good link though, it has all the information to do it safely.
(in reply to superballz00)
Post #: 12
RE: ? for computer gurus - 10/23/2007 4:20:57 PM
nafango2
Status: offline
the ABSOLUTE number one way to stop spyware or malware:
switch to *nix.
96 Accord LX 4cyl. 4dr AT w/o vtec (F22B2)
Security System / Keyless entry
Post #: 13
RE: ? for computer gurus - 10/23/2007 4:37:05 PM
Status: online
Here is a site that Iv'e been hooked up with for about 5 years..Look it over..it keeps my computer on the up and safe side...it e-mails me every day with tips and things to watch out for...no cost involved...
www.zdnet.com
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
(in reply to Trav20)
Post #: 14
RE: ? for computer gurus - 10/23/2007 5:31:45 PM
superballz00
Status: offline
quote:
ORIGINAL: sir_nasty
I know that there is a disable services option in msconfig but they might still start up. The only sure way to disable them is using services.msc.
Post #: 15
Honda Accord Forums >> General >> Off Topic
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7078
sir_nasty6309
falkore245923
finch134264
00accordlx5s3815
deserthonda3575
live2rice3434
jimblake3268
19accord973171
smaglik2623
New Vendors
Sportwing
