[Deleted]
  Printable Version
Honda Accord >> General >> General Tech Help >> [Deleted] Page: [1]
Login
[Deleted] - 4/28/2006 3:54:44 PM
Deleted User
[Deleted by Admins]
  Post #: 1
RE: Crazy car 93 accord - 4/28/2006 5:44:09 PM
sir_nasty
Status: offline
pull one of the spark plugs after you turn it over for a while and see if there is any fuel on it.... if there is then I would guess it's a spark issue... Does it do anything else that's funny? does it do this after the car has warmed up/been run for a while? what engine do you have?
WELCOME TO THE FORUM!!
(in reply to Deleted User)
Post #: 2
RE: Crazy car 93 accord - 4/28/2006 6:02:25 PM
deserthonda
Status: offline
we need to verify if it is lack of spark or fuel..
Here is what you do,, get a can of carb cleaner do not get start fluid,, that thing sucks..
anyho,, when car does not start, remove the intake tube that goes to throttle body, open the butterfly and spray some carb cleaner in throttle body, crank the engine ,if it starts it is lack of fuel
common problem on those MAIN RELAY .. could be FUEL PUMP. as well
here is some info on main relay ...
http://techauto.tripod.com/s.htm
if still does not start, pull a spark plug wire, if you have an old plug insert it into the wire , ground the plug, crank the engine and chk for spark, if you do not have an old plug you can use a screwdriver, ..make sure to ground the metal part and chk for spark, ,,if no spark
common problem IGNITOR, COIL ,ROTOR., would have to test to properly diagnose
try this and post results we will go from there
< Message edited by deserthonda -- 4/29/2006 11:31:08 AM >
Post #: 3
RE: Crazy car 93 accord - 4/28/2006 9:29:06 PM
lightshow
Status: offline
i think its the main relay
(in reply to deserthonda)
Post #: 4
RE: Crazy car 93 accord - 4/29/2006 11:40:22 PM
deserthonda
Status: offline
Yo Barryl ,, let us know what you find..
(in reply to lightshow)
Post #: 5
Page:   [1]
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2646
smaglik2594
New Vendors
Sportwing
