[Deleted]
  Printable Version
Honda Accord >> General >> General Tech Help >> [Deleted] Page: [1]
Login
[Deleted] - 4/22/2007 10:59:53 AM
Deleted User
[Deleted by Admins]
  Post #: 1
RE: 1994 Accord Motor Mounts - 4/22/2007 11:31:36 AM
Shadow1992
Status: offline
There are 4 mounts total..there is another one near the firewall below the intake manifold. Kinda hard to see.  To do a check you need to get a dolly jack and place it under the oil pan and lightly jack up the engine so pressure is taken off the mounts. Then look at the mounts checking for tears or cracks, make sure the rubber isn't hardened or seperated from the metal. Then check to make sure the mount is securely attached to the frame, you can use a large screwdriver to pry on it to see if it moves. If it does lower the engine and tighten the mount bolts. Apply rubber perservative to the mounts to slow deterioration.
_____________________________
1992 Accord EX
massively modifed H22A
2.5L stroker kit
GT35R turbo @ 24psi
459 whp
404 ft-lbs torque
(in reply to Deleted User)
Post #: 2
Page:   [1]
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2646
smaglik2594
New Vendors
Sportwing
