[Deleted]
Login | |
[Deleted] - 1/15/2005 6:03:56 PM
Deleted User
[Deleted by Admins]
[Deleted] - 1/15/2005 6:06:30 PM
Deleted User
[Deleted by Admins]
RE: Exhaust upgraded then ... my car slower - 2/19/2005 7:37:45 AM
RTexasF
Forum Monitor Posts: 2347
Joined: 11/16/2004 From: Brownsville, TX Status: offline
It's possible that it is simply too large in size. All engines need some backpressure to make max horsepower.
< Message edited by RTexasF -- 2/19/2005 7:38:06 AM >
RE: Exhaust upgraded then ... my car slower - 3/16/2005 7:34:41 PM
2000Ex
Backpressure is a myth but if it is not the right size you can hinder performance.
RE: Exhaust upgraded then ... my car slower - 3/23/2005 8:01:00 AM
RTexasF
quote:
ORIGINAL: 2000Ex Backpressure is a myth but if it is not the right size you can hinder performance. I disagree. I have witnessed dyno runs with and without open exhaust. In one case the engine made more HP WITH some restriction/backpressure. Not true in all cases I admit, but to call it a myth is not correct.
< Message edited by RTexasF -- 3/23/2005 8:02:38 AM >
RE: Exhaust upgraded then ... my car slower - 3/23/2005 11:48:01 AM
Patrick
smaller CC engines requrie a certain amount of back pressure...even V8s require some back pressure...you dont want to have a higher volume of exhaust flow than you do exhaust valve size. for instance, on a V8 i built...it has 1.67inch exhaust valves, the guy bought 1 7/8 inch headers, which were too big...he found that he had more low end torque with a 1 5/8 inch headers...you dont actually lose power, you lose initial torque..the reason people say that "smaller engines are more affected, is because they have less low end torque. take 2 cars, for example...a 2002 Accord V6, and a 2002 Camaro SS. you can hinder low end torque on both vehicles by putting too big of an exhaust system on them, but the camaro has around 300ft/lb of torque, whereas the accord only has around 175 (i think) so when a oversized exhaust may cause, say, a 10% low end torque loss, it is alot more determental on the accord with the smaller engine.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
