[FAQ] 7th Gen Strut Bar Installation Guide
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> [FAQ] 7th Gen Strut Bar Installation Guide Page: [1]
Login
[FAQ] 7th Gen Strut Bar Installation Guide - 4/11/2007 8:28:25 PM
03Sleeper
Score: 0
Status: offline
03Sleeper's photo gallery
Intro: Hello, hello. 03Sleeper here bringing HAF another 7th gen aftermarket install...this time the front strut bar. The strut bar is T6061 Alumnium with a White CF finish bought from EBay. Don't worry though...it fit perfectly...no bending, no cussing, etc.
Tools: Socket wrench (9/16" socket bit aka 14 mm), Brute force (you) [I had a pretty cool adjustable wrench...that violated the righty tighty, lefty loosey rule. It became righty loosey, lefty tightey. Maybe I'm just socket wrench incomptent.]
Two bracket assemblies, one strut bar.
Step 1: Put the parking brake on. Pop the hood. Go to where your strut brace/tower is. The two outer washers is what we want to remove at this point.
Step Two: Install the two brackets. I suggest you screw on lightly one part of the strut bar itself...it's rather heavy because of your point of engagement. Using the stock washers, tighten into position...not all the way. This is the right side [The easier side...just move that cable a bit for the bracket to fit.
Bracket assembly installed.
Here comes the more challenging part and requires a little brute force. The removal of the washers is the easy part. Putting on the bracket in that position is the hard part. I suggest you slide/slot the upper part of the bracket into the bolt first. Then remove the bolt holding the two metal tubes together and gently lift up on the metal tubes. Slide the lower part of the bracket to the bolt...or close to it. Then using the end of your wrench or screwdriver, lightly tap down to ensure proper fitment. Sorry about the images...it was getting dark.
Step Three: Next, install the strut bar itself. If you were smart and installed one end of the strut bar, good for you! If not, it's ok. You just have to remove one bracket...screw in the bar, then screw it into the other bracket, reinstall the bracket and place the washers on the bar so the fitment is tight. Then tighten the bolt that is on the bracket itself. Do that on both sides.
Step Four: Tighten any remaining bolts and check everything is working order. Make sure the brackets are in contact with the tower with a flat bottom.
  Matches the engine bay quite nicely...although I wished it was jet black.
Notice the bolts: Two on the tower and one on the bracket assembly needs to be tightened. Times two. (One on each side). I get better pictures in the afternoon.
Conclusion: Total Time: 20 minutes. I was being dumb so I had to relearn how to use a socket wrench. I still don't understand how rightey = loose and lefty = tighten but whatever. Yes it's an eBay strut bar but it's real solid, heavy, and wide. In short, just what a strut bar should be. It's like the people who purchase Bomz CAIs or SRIs and get the same effect as someone who purchases an AEM or Injen. As you can tell...the CF finish is just crud. You need to go up real close to notice it and when you do, you know it's a fakie. But from a distance, it appears to be a respectable strut bar. Great finish and polish! Cornering, sharp turns, and weaving abilties all have increased tenfold. It's amazing what a bar can do for the engine in its elimination of body lean. Overall, a worthy addition to anyone's car!
< Message edited by 03Sleeper -- 4/11/2007 8:30:49 PM >
_____________________________
2003 Accord LX Sedan I4| 5AT 101045
Injen SRI w/ AEM Dryflow| DCSports Ceramic Headers| DENSO IK20 Sparks| CF Front Strut Bar| Pioneer TSG950M 6x9s| Alpine SPS17C2 6.5"| C-Tek Slotted/Drilled Rotors | Progress 24mm Rear Sway Bar
Post #: 1
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 4/12/2007 12:13:36 AM
03Sleeper
Score: 0
Status: offline
I call upon the mighty powers of deserthonda to copy this to the 7th gen DIY.
(in reply to 03Sleeper)
Post #: 2
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 4/12/2007 12:14:01 PM
Fenix
Score: 0
Status: offline
Fenix's photo gallery
Thx 03Sleeper, this may be the next purchase for my baby. and its great to know how to do it before i go and do it. Thx again and Go 7th Gen's
04 EX 4cyl 5AT Coupe
Fujita CAI
Custom Heads & TYC Tails
Apexi WS2 Cat Back Exhaust
Front Grill
Interior LED rods(7color)
20% Tint
TSX Intake Manifold
DC Ceramic Header
Ralco Light Weight Pullies(In Hand)
Post #: 3
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 4/12/2007 5:41:41 PM
03Sleeper
Score: 0
Status: offline
No problem. Anything to further the cause of the 7th gens.
(in reply to Fenix)
Post #: 4
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 4/25/2007 8:44:30 AM
bssmagik83
Score: 0
Status: offline
bssmagik83's photo gallery
Is this the strut bar you used?
http://cgi.ebay.com/ebaymotors/FRONT-CARBON-FIBER-STRUT-BAR-FOR-03-05-HONDA-ACCORD-04_W0QQcmdZViewItemQQcategoryZ33591QQihZ013QQitemZ230120256642QQrdZ1
2004 lx V6 Coupe
Tein S Tech's
KYB GR2
BT Freestyle 18x8/Kumho 711's
JBL bp1200.1
Kicker SL7 15"
Fujita CAI
6mt front strut bar
Magnaflow 14851's with custom pipe
Post #: 5
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 4/25/2007 9:06:38 AM
03Sleeper
Score: 0
Status: offline
Yep.
(in reply to bssmagik83)
Post #: 6
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/16/2007 3:13:24 PM
03Sleeper
Score: 0
Status: offline
Testiment #1
Turn (about 60 degrees) onto intersection at 45 mph....tires were squealing (4 years old...OEM Michelins) but I didn't even feel the body shift one bit. Definately worth my money on the product. By accident, I shifted down to 1 too...my elbow hit it. I was surprised at the sound because I seriously thought the car was just taking another bank turn...just another day at the office.
Post #: 7
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/16/2007 3:24:20 PM
Score: 0
Status: offline
quote:
ORIGINAL: bssmagik83
That link didnt work for me, got another one that works?
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
Post #: 8
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/16/2007 6:49:30 PM
03Sleeper
Score: 0
Status: offline
I guess they ran out....?
(in reply to WheelBrokerAng)
Post #: 9
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/16/2007 7:16:31 PM
smaglik
Score: 0
Status: offline
Is this the only suspension related mod you've done?  How much was it?  It looks very appealing.
1987 BMW 635csi 5MT
1995 Honda Passport LX 4WD 6CYL 5MT
Post #: 10
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/17/2007 5:56:13 AM
03Sleeper
Score: 0
Status: offline
Yeah....I only dropped 20.99 for it....best use of $21 in my life
(beats out my V-day gift for my girl) ;)
(in reply to smaglik)
Post #: 11
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/17/2007 7:02:17 AM
smaglik
Score: 0
Status: offline
This very well may be in my future.
1987 BMW 635csi 5MT
Post #: 12
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/17/2007 6:13:13 PM
bil6ly05
Score: 0
Status: offline
im plannin on getting one of these plus a rear one for a 5th gen  is there that big of a noticable difference
blue 94 accord lx 4door mt
2.2L non vtech soch
option racing cold air intake
halo projectial headlights
carbon style tail lights
2 rocksford fosgate p3 subs
1000 watts max 500 rms a peice
clarion DPX 11500 amp
1500w rms @1ohm
Post #: 13
RE: [FAQ] 7th Gen Strut Bar Installation Guide - 5/17/2007 8:52:52 PM
03Sleeper
Score: 0
Status: offline
Stiffer ride = better cornering = better weaving in and out of traffic.
The strut bar makes the hefty Accord weave in and out like a Fit. No, I'm being serious. Fishtailin is entirely eliminated.
(in reply to bil6ly05)
Post #: 14
Page:   [1]
Honda Accord Forums >> General >> Do-It-Yourself Section
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2646
smaglik2594
New Vendors
Sportwing
