1988 Honda Accord Transmission Fluid Change
Login | |
1988 Honda Accord Transmission Fluid Change - 5/10/2006 12:02:24 PM
mossimo817
Score: 0 Joined: 5/10/2006 Status: offline
Can anyone give me some detailed instructions on how to change the transmission fluid on my 1988 Honda Accord? I also need to know what type of fluid to use and what filter to get. Thanks! Mike
RE: 1988 Honda Accord Transmission Fluid Change - 5/10/2006 2:39:52 PM
sir_nasty
Score: 0 Joined: 2/23/2006 Status: offline
is it an automatic or manual?
RE: 1988 Honda Accord Transmission Fluid Change - 5/10/2006 3:50:56 PM
mossimo817
Automatic...
RE: 1988 Honda Accord Transmission Fluid Change - 5/10/2006 7:00:24 PM
sir_nasty
If I remember correctly there is no filter.... you can wait for someone else to post or even see if the part is availble... if it doesn't exist then you don't need to change it... as for flushing it just pull out the dipstick then crawl under the car and on the bottom of the tranny you will see a bolt that generally has a hole in it that fits a 1/4" drive socket wrench, put the wrench in there and back it off and allow it to drain.... then just fill it to where it's supposed to be (start with two quarts of Honda ATF Fluid, check with your local dealer....) make sure you don't overfill it...
RE: 1988 Honda Accord Transmission Fluid Change - 5/10/2006 9:32:32 PM
AgentofDarkness
Score: 0 Joined: 2/11/2006 Status: offline
I haven't worked with any Honda Accord transmissions, but i have worked on a Chevy 305 trans and a trans out of a 92 Nissan Sentra. Both transmissions had filters, neither had any type of drain plug. Manual transmissions do not have filters, but an automatic transmission has a pump that pumps the fluid and i'm pretty sure that they all have filters. If there was a filter, when you take the pan off you will see it. However, i am not completly sure since i have never worked on an accord trans. I would think that there would be a filter b/c crap could get into the trans some how.
RE: 1988 Honda Accord Transmission Fluid Change - 5/11/2006 4:05:49 AM
deserthonda
Score: 0 Joined: 12/3/2005 Status: offline
Sir nasty pretty much explained how to,, as for the atf fluid,, first of all ,, change and refill you will need 3 qts, on your car you can save some money and use DEXRON III OR IV any brands will do ,, if you got the extra money, use HONDA ATF-Z1 , the dipstick is located on top of tranny , below the lower radiator hose, remove it , put a funnel in the hole and add 3 qts of tranny fkuid .. As for the filter, ,, all Hondas have a filter but it is unreplacable,,, it is located, between the pump and the valve body,, to get to it , one would have to totally disassamble the tranny intrnally ,, ,,there is no tranny filter that you can replace as of yet .. And honda trannies do not have a removable pan ..
< Message edited by deserthonda -- 5/11/2006 10:01:43 AM >
_____________________________
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
