1991 Accord automatic transmission problem
Login | |
1991 Accord automatic transmission problem - 9/19/2008 7:28:47 PM
scasper
Score: 0 Joined: 9/19/2008 Status: offline
I have a 1991 Accord with an automatic transmission. The engine and trans were pulled from a ''92 with 90,000 miles. The problem is sometimes the transmission shifts and kicksdown fine, other times, it will not kickdown at all and shifts thru all gears at about 3200 rpm at wide open throttle. The kickdown linkage is adjusted correctly from what I have read. It does not seem to make any difference if the engine is warm or cold. I have tried cleaning all of the electrical connections going to the transmission. I have checked the trouble codes, no transmission codes come up. Any suggestions? Thanks! Scott
RE: 1991 Accord automatic transmission problem - 10/5/2008 8:10:03 PM
scasper
Update: I swapped the engine and transmission ECU''s from the ''92 Accord the engine and trans came out of. It seems to have taken care of the problem-for now. I will post again if the problem comes back.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
