1997 Honda Accord stuck in park
Login | |
1997 Honda Accord stuck in park - 11/3/2006 7:03:01 PM
tampabayshore
Score: 0 Joined: 11/3/2006 Status: offline
Hi, I am first time poster. I have a 1997 Honda Accord Ex 4 cyl, auto with 120k miles Just recently, its been taking quite a few tries to release the shifter from Park into Reverse or Drive. Not sure why. I have to repeatedly squeeze the button on the shifter, while pumping the break petal, and eventually it releases. Was wondering if anyone had any ideas on why? Thanks again! Brian
RE: 1997 Honda Accord stuck in park - 11/3/2006 7:33:26 PM
sir_nasty
Score: 0 Joined: 2/23/2006 Status: offline
welcome to the forum! it could be either the button on the shifter is sticking for some reason or the brake release switch, try holding the switch down and trying to shift (when it's stuck) and then slowly pump the brakes, if it all of the sudden releases it may be a bad brake switch, to test it you'll find the switch under the dash around the top of the brake pedal arm and you can then jumper the two wires (giving the signal that the brake is depressed) and see if you can shift just fine then, if you can then you know your problem! Hope this helps
_____________________________
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''''s great but it''''s not all beer and skittles
RE: 1997 Honda Accord stuck in park - 11/4/2006 12:21:08 AM
deserthonda
Score: 0 Joined: 12/3/2005 Status: offline
try a quick test.........when you cannot get car out of park, have someone step on the brakes and see if the brale lites work,, if not most likely a bad brake switch like Nasty said... also blow the horn, if it works the fuse is ok,, brake lites and horn share the same fuse
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: 1997 Honda Accord stuck in park - 11/7/2006 10:48:27 AM
tampabayshore
Thanks again for your help. In the meantime, I will just use a key to manually depress the shift release until I can figure it out. I just don't want to to invest major $$ in a fix, and I know the dealer can kill you on that sort of thing. regards, Brian
RE: 1997 Honda Accord stuck in park - 11/7/2006 10:48:35 AM
tampabayshore
RE: 1997 Honda Accord stuck in park - 11/7/2006 12:40:55 PM
sir_nasty
this is something you can easily diagnose and fix yourself if it's just that switch, I'm talking like $30.00 for a part and 30 minutes of your time... check the brake lights like desert said and go from there, don't pay someone to do this we'll take you through it
RE: 1997 Honda Accord stuck in park - 11/7/2006 9:15:07 PM
tampabayshore
OK--I just check the brake lights..and they are working Next step---I will follow your steps looking at the brake pedal and try jumping the wires. PS: What was that $30 part you suggested? thanks again, Brian
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
