1998 accord coupe LX-V6 cracked clear coat
  Printable Version
Honda Accord Forums >> Your Ride >> Appearance >> 1998 accord coupe LX-V6 cracked clear coat Page: [1]
Login
1998 accord coupe LX-V6 cracked clear coat - 5/28/2006 9:53:05 PM
YeuEmMaiMai
Status: offline
I have a problem and I need a solution
The clear coat is craked on both of my front fenders. Short of taking the car to the paint shop and getting the fenders redone (big cash) what can I do?
I have waxed it really well and you cannot feel the cracks anymore
_____________________________
Jesus is Salvation
White 2002 Acura CL type S. 68K and change
Criminals thrive upon the intolerence of society''s understanding.....and political correctness
Post #: 1
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/28/2006 10:03:47 PM
deserthonda
Status: offline
Yeu,,,,,,,, talk to RtexasF . he is real good with that stuff
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
(in reply to YeuEmMaiMai)
Post #: 2
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/28/2006 10:39:40 PM
RTexasF
Forum Monitor
Status: offline
RTexasF's photo gallery
Any chance of getting a picture of the cracks? Depending on the severity it's possible it could be wetsanded then polished. This is something for a pro to do but I can only guess without seeing the detail of the cracking.
Can you still see the cracks even though you can't feel them?
''''04 2.4l 5M EX Sedan
Neuspeed short shift kit
V-6 6 speed front strut/firewall brace
17mm rear anti sway bar
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Clean Sweep
JL Audio Amp
200W Bazooka sub
V-6 OEM 7 spoke alloys
(in reply to deserthonda)
Post #: 3
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 12:30:44 AM
Status: offline
RTexasF will soon be Voted in on becoming the Car Finish Guru...what do you think Gianni?
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
Post #: 4
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 7:24:44 AM
YeuEmMaiMai
Status: offline
Yes you can see them only when you are right up on it.... I'll see what I can do for posting a pix
(in reply to RTexasF)
Post #: 5
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 7:45:29 AM
RTexasF
Forum Monitor
Status: offline
quote:
ORIGINAL: WheelBrokerAng
Thank you but....... I can make our cars sharp and most others but a Guru? Nope, still much to learn. I am strictly an enthusiast amateur not a professional by any means.
< Message edited by RTexasF -- 5/29/2006 7:55:36 AM >
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
(in reply to WheelBrokerAng)
Post #: 6
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 7:46:42 AM
RTexasF
Forum Monitor
Status: offline
quote:
ORIGINAL: YeuEmMaiMai
That will help if you can get a good shot. Are you aplying wax by machine or by hand? Is the clear coat peeling anywhere or just cracking?
< Message edited by RTexasF -- 5/29/2006 7:56:42 AM >
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
Post #: 7
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 8:25:35 AM
YeuEmMaiMai
Status: offline
it's just cracked like this
I waxed the car by hand and it is only on the front fenders The hood, roof, trunk and side panel are just fine
Post #: 8
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 9:03:17 AM
RTexasF
Forum Monitor
Status: offline
The best you can hope for, without a complete repaint, is to hide/fill the cracks as best you can. It sounds like you have done a bit of this by waxing since they are less noticeable than before. They will reappear but you can minimize them by using a glaze or polish with fillers to hide the imperfections. Here is what I would use:
http://www.autogeek.net/meg9swirrem.html This will NOT repair the problem it will minimize it though. Do a small test section, about 1'X1' following the directions on the bottle. A microfiber towel will be best for this but terrycloth will work. Use light pressure, don't bare down on it. Once you have applied and removed the product TWICE do the same with wax. Stand back and look at the difference between this area and the rest. If it is noticeably better then go for it. If not it was an inexpensive experiment and it will work well on the rest of the car so you haven't wasted your $$.
Here is another product you can try: http://www.autogeek.net/megscratxfin.html. Both of these may be available locally so check around.
Keep in mind that this is an experiment that I think will help but no guarantees. It's worth a try and certainly less money than the paint booth!
< Message edited by RTexasF -- 5/29/2006 9:30:32 AM >
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
Post #: 9
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 11:20:36 AM
YeuEmMaiMai
Status: offline
I just want to keep it from rusting out, I might try wet sanding it and reapplying the clear coat if the above does not work out....
Jesus is Salvation
Post #: 10
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 1:03:10 PM
RTexasF
Forum Monitor
Status: offline
I wouldn't think rusting would be a problem if only the clear coat is cracking, the paint beneath it would stop water intrusion. Wet sanding requires special skills and a rotary buffer to polish out the sanding marks. In turn a rotary buffer can remove paint COMPLETELY, in a heartbeat, so it requires skill as well! If you don't know what you're doing you'll end up at the body shop anyway so figure out if you want to minimize the looks or just get it fixed properly...... and you're welcome.
< Message edited by RTexasF -- 5/31/2006 10:36:17 AM >
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
Post #: 11
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 2:55:02 PM
deserthonda
Status: offline
He definately has my vote... Ok,, RTEXASF.. the car Finish GURU ..mmmm it does have a nice ring to it , don't you think ??
No Help from me
Post #: 12
RE: 1998 accord coupe LX-V6 cracked clear coat - 5/29/2006 3:09:53 PM
RTexasF
Forum Monitor
Status: offline
quote:
ORIGINAL: deserthonda
Thank you both but it's also
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
Post #: 13
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2646
smaglik2594
New Vendors
Sportwing
