1999 HonDa Accord Timing Belt
Login | |
1999 HonDa Accord Timing Belt - 9/12/2005 9:54:53 PM
waikikiguy
Hi My name is Ed and Im new on this forum.I have a 1999 honda accord,V6 V-tech.I'm thinking about installing a new timing belt .I would like to know how hard to change timing belt on 99 accord.Is there a special tool I might need ?Do I have to lift the engine to get some room?is there a web site to showing how to do it . .Your response would be great appreciate . .Thank you in advance!!
RE: 1999 HonDa Accord Timing Belt - 9/12/2005 11:38:27 PM
Joined: 8/30/2004 From: Canton/Massillon, Ohio 44646 Status: offline
Hi Guy... Welcome to the forums, we thank you for joining up.. While your in there changeing that timeing belt dont forget to also change the balance shaft belt at the same time. You will need a floor jack and a box of good tools and also a large screwdriver or large punch and a breaker bar and socket. Dont forget how you took them off cause you got to put them back on the same way... Good Luck & Bust A Knuckle For Us All....just kiddin of course WheelBrokerAng
_____________________________
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
RE: 1999 HonDa Accord Timing Belt - 9/13/2005 8:49:34 PM
waikikiguy
Thank's WheelBrokerAng . .I'm ready to do it this coming weekend. Anybody else would like to make a recomendation. Thank you . . . Ed
RE: 1999 HonDa Accord Timing Belt - 9/13/2005 11:20:31 PM
dinzer
dude, aloha, was in maui a few months back, wow is all i can say, great driving roads on the north side!!! buy yourself a manual before you do it, unless your a pretty skilled mechanic the job is pretty involved and you have to watch your timing marks.. get the haynes repair manual, gives you step by step info good luck
RE: 1999 HonDa Accord Timing Belt - 11/15/2005 10:51:53 PM
beets442
just rebuilt 90 accord ,replace water pump,crankseal,camseal while your there-3/4 drive impact to get crank bolt off-not a bad job. need someone with small hands- good luck
RE: 1999 HonDa Accord Timing Belt - 12/4/2005 8:56:50 PM
deserthonda
yo WHEELBROKER ,,,v6 does not have a balancer belt to replace ,, i would however advice to replace the Hydraulic tensioner ............i would strongly as well advice to get a factory helms manual if u plan on doing the job urself..,,,,,,If u are not mechanically inclined take it to a shop..
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
