2000 honda accord auto trans swap help
  Printable Version
Honda Accord Forum >> General >> Do-It-Yourself Section >> DIY Requests >> 2000 honda accord auto trans swap help Page: [1]
Login
2000 honda accord auto trans swap help - 10/7/2008 7:26:06 AM
vipernj
Score: 0
Status: offline
hey guys,
Car - 2000 Honda Accord SE VTEC 4 cyl Auto 209,000 miles runs great
Problem - The mechanics in the tranny have failed causing very, very low fluid pressure resulting in slippage(among other things) - This tranny was originally replaced by Honda at 77,000 Miles as part of their recall.
Solution - I brought the car to a Transmission specialist. They were going to charge me $500 just to crack it open an tell me whats wrong. Then $1900 for a rebuild kit + labor.. The car has too many miles for that.
So, I want to replace the trans myself with one from a junkyard or something, but:
QUESTIONS -
1. If I find a used automatic transmission, what else do I need to have it properly work? ie, computer, harnesses?? Or will it be direct swap and work just fine?
2. Would any Honda Accord 4 cyl trans bolt up? or do I need a 98-02 specific?
3. If Honda recalled all those transmissions, would me getting one out of a totalled Accord result in failure as well?
4. Would I be better off swapping the trans out for a manual? and if so, can I follow instructions from a 93 Accord swap?
The car has 209,000 Miles on it. I''ve taken care of it for all these years and I really want to keep it as my daily. I just need to know these few things so I can start finding a trans.
Thanks all!
Vipernj
Post #: 1
RE: 2000 honda accord auto trans swap help - 10/7/2008 7:44:55 AM
finch13
Score: 0
Status: online
quote:
ORIGINAL: vipernj
hey guys,
QUESTIONS -
The car has 209,000 Miles on it. I''''ve taken care of it for all these years and I really want to keep it as my daily. I just need to know these few things so I can start finding a trans.
Thanks all!
Vipernj
1. You should only need the transmission itself. Your car is already rigged to operate it properly.
2. You would need a 98-02 auto tranny.
3. There is a 50% chance the transmission you swap in will fail, unless you overhaul/rebuild it before you put it in.
4. If you don''t rebuild it I''d swap in a manual. It''s just as hard and just as expensive, so I''m sitting on the fence about it. At the same time the manual tranny will probably last longer than the auto. Your call. Yes, the 93 swap is similar, but you probably can''t follow it to a T.
_____________________________
USE ME TO SEARCH HAF
99 Accord F23A1 5MT
(in reply to vipernj)
Post #: 2
RE: 2000 honda accord auto trans swap help - 10/7/2008 8:01:02 AM
vipernj
Score: 0
Status: offline
Ok that clears some things up.
The transmission specialist told me that i needed the computer out of the same car I pulled the tranny from along with other parts. I''m pretty sure he just wanted me to get it done there so he could rape me in price.
Ok so all I need is the tranny itself.
I''m going to call Honda of America for questions as well. I have heard of a few people who have called and actually have gotten a new auto trans, installed from a Honda Dealer for ~$1200. Now I don''t know if this is true but it''s worth calling about.
I want to do the manny swap... but I rather inquire about the auto trans just cause it''s so much easier to swap in.
Have you done or seen a successful manny swap in a 6th gen?
quote:
ORIGINAL: finch13
4. If you don''''t rebuild it I''''d swap in a manual. It''''s just as hard and just as expensive, so I''''m sitting on the fence about it. At the same time the manual tranny will probably last longer than the auto. Your call. Yes, the 93 swap is similar, but you probably can''''t follow it to a T.
(in reply to finch13)
Post #: 3
RE: 2000 honda accord auto trans swap help - 10/7/2008 8:38:54 AM
finch13
Score: 0
Status: online
Yes, I have seen many a success... In fact I''ll find one for you.
Check this out (copy/paste): http://www.v6performance.net/forums/showthread.php?t=54643
99 Accord F23A1 5MT
Post #: 4
RE: 2000 honda accord auto trans swap help - 10/7/2008 8:47:21 AM
vipernj
Score: 0
Status: offline
You sir..... are the greatest member to ever post! I''ve been looking for that article for a while! Thanks
Post #: 5
RE: 2000 honda accord auto trans swap help - 10/7/2008 9:04:22 AM
finch13
Score: 0
Status: online
Not a problem, that''s what I''m here for!
99 Accord F23A1 5MT
Post #: 6
Page:   [1]
Honda Accord >> General >> Do-It-Yourself Section >> DIY Requests
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2646
smaglik2594
New Vendors
Sportwing
