2001 Accord Drinks OIL !!
  Printable Version
Honda Accord >> Your Ride >> Engine & Internal >> 2001 Accord Drinks OIL !! Page: [1]
Login
2001 Accord Drinks OIL !! - 10/26/2008 5:45:58 AM
Wizcat
Status: offline
Hello All, I have a question concerning a 2001 SE 4door 2.3 vTec 5spd 174,000 km''s
It drinks oil at rate of 1 liter per tank of fuel, when driving the car you can see visible whitish grey smoke from the back end (no leaks what so ever at the engine). I have had a compression test done and that came back with 175+- numbers across all cylinders and they said the head gasket was fine as well. The more information I gather points to the rings? If I have to replace the bottom end, am I better off going to another engine type for this car (what will fit without rebuilding the entire car?). I have read a lot of other posts about similar (but not as much) oil consumption and was wondering if anyone out there has any suggestions about the path I should take. The car it''s self is in great shape so investing a few dollars seems worth the effort.
Regards,
David
Post #: 1
RE: 2001 Accord Drinks OIL !! - 10/27/2008 7:48:00 AM
falkore24
Status: offline
falkore24's photo gallery
Check you PCV.  If you have an even compression test, your rings are fine.
_____________________________
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to Wizcat)
Post #: 2
RE: 2001 Accord Drinks OIL !! - 10/27/2008 8:08:40 AM
live2rice
Status: online
live2rice's photo gallery
yeah the compression test would tell you if the rings were bad, I would check the PCV, although that is a ton of oil for just a PCV, i would think th likely culprit would be the valve seals.
and welcome, Honda Accord Forum Oil Burner Club Member #2
quote:
ORIGINAL: hondadude
I would not put a fram filter on a lawnmower engine...
1997 Fiji Blue Pearl CD7
1995 Sage Green Metallic CD5
(in reply to falkore24)
Post #: 3
RE: 2001 Accord Drinks OIL !! - 10/27/2008 8:22:44 AM
falkore24
Status: offline
true, I didn''t think of the valve guides.
2000 V6-AT (RIP 3G)
(in reply to live2rice)
Post #: 4
RE: 2001 Accord Drinks OIL !! - 10/28/2008 11:26:41 AM
Wizcat
Status: offline
Thanks for the info, I will get a price on the service and see if it is something they can do soon. Is there anything else that should be done while the have it apart aside from the belt and pump, that was done in the spring.
Post #: 5
RE: 2001 Accord Drinks OIL !! - 11/2/2008 12:56:51 PM
Mikkos
Status: offline
WOW! I was just getting ready to post the exact same thing about my veh.I have a 2001 EX 4cyl with 243,000 miles. My car smokes from time to time when I take off from stop lights or stop signs. It''s driving me crazy and I hate to see the smoke. I have been told that the valve seals are bad as well. Is there anything else that could possibly cause the engine to smoke like this?
2001 Accord EX-4cyl
Post #: 6
RE: 2001 Accord Drinks OIL !! - 11/2/2008 1:06:41 PM
live2rice
Status: online
quote:
ORIGINAL: Mikkos
WOW! I was just getting ready to post the exact same thing about my veh.I have a 2001 EX 4cyl with 243,000 miles. My car smokes from time to time when I take off from stop lights or stop signs. It''''s driving me crazy and I hate to see the smoke. I have been told that the valve seals are bad as well. Is there anything else that could possibly cause the engine to smoke like this?
valve seals, piston rings, pcv........those are pretty much all the different reasons for burning oil
quote:
ORIGINAL: hondadude
(in reply to Mikkos)
Post #: 7
RE: 2001 Accord Drinks OIL !! - 11/10/2008 4:55:40 PM
Mikkos
Status: offline
Well I had my PCV valve looked at by the Honda dealer and they didn''t a need to change it. I change my oil every 3,000 miles. I''ve never been late in doing that. The piston rings were changed this year as well. The only thing that is left is the seals..
2001 Accord EX-4cyl
Post #: 8
Page:   [1]
Honda Accord Forums >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134329
00accordlx5s3815
deserthonda3575
live2rice3471
jimblake3290
19accord973171
smaglik2623
New Vendors
Sportwing
