88 Accord won''t idle please help
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> 88 Accord won''t idle please help Page: [1]
Login
88 Accord won''t idle please help - 9/27/2008 5:40:02 PM
dumbear33
Status: offline
Boy I need some help here badly, I have worked on cars all my life but this problem has me stumped. Hopefully somebody knows how to fix it. My 1988 Accord (carbureted, with auto trans, 216,xxx miles 60K on rebuilt motor) will not idle, but runs great at driving speeds. Below is a list of everything that has been done as of today.
Primary slow mixture cut-off solenoid valve - replaced new
PCV valve replaced new
Rebuilt the carburetor
Oxygen sensor replaced new
carb base gaskets - new
checked & traced down all vacuum lines
cleaned the egr valve and replaced gaskets
replaced the vacuum advance on the distributor
replaced dist-cap, rotor, wires and plugs all new
replaced fuel filter
I''m stumped, Please help if you can it seems to be a common problem with the older accords but their is no info on how to fix the issue.
Thanks in advance for your help
Post #: 1
RE: 88 Accord won''''t idle please help - 9/27/2008 11:26:56 PM
deserthonda
Status: offline
chk to make sure that the slow-mixture solenoid is working properly, turn the key on and off  and listen if solenoid clicks .or remove solenoid and see if the little plunger retracts with key on,,
get a can of carb cleaner and spray around the intake manifold ,,for a possible int manifold  gasket leak .
you are positive that the is no vacc hose leaking???  there are a crap load of vacc hoses ,,get a needle nose plier and pinch vacc hoses 1 by 1 see if idle smooths up ..
when you say will not idle do you mean idles rough  or dies at idle ???
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
(in reply to dumbear33)
Post #: 2
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133274
jimblake3137
19accord973125
live2rice2646
smaglik2594
New Vendors
Sportwing
