96 VTEC 4 cyl misfires
  Printable Version
Honda Accord >> General >> General Tech Help >> 96 VTEC 4 cyl misfires Page: [1]
Login
96 VTEC 4 cyl misfires - 7/22/2008 12:10:52 PM
Hondaccord
Status: offline
New plugs-EGR working- misfires under light load but runs smooth and strong upon accelleration. Where to look? Short post due to forum problem
_____________________________
2000 Accord V6 CDN.4 dr auto
1984 Honda Goldwing
Post #: 1
RE: 96 VTEC 4 cyl misfires - 7/23/2008 6:05:24 AM
Hondaccord
Status: offline
Hopefully, I can add more text here in a second post. The ECU threw a P0304(#4 misfire, and the CEL blinks during the misfiring-according to the owner) It really vibrates at a feathered throttle, but runs strong and smooth upon acceleration. It is getting new wires, dist cap and button today, but I doubt that is the fix. Could it be the tranny(torque lockup) Will report back.
1984 Honda Goldwing
(in reply to Hondaccord)
Post #: 2
RE: 96 VTEC 4 cyl misfires - 7/23/2008 7:06:12 AM
JimBlake
Status: offline
Tranny & TC might FEEL like a misfire, but they shouldnt set off P0304.
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
Post #: 3
RE: 96 VTEC 4 cyl misfires - 7/23/2008 2:51:27 PM
trukid21
Status: offline
check your fuel injectors. i had the same issues with my car before and i had my fuel injectors cleaned and yeah i also cleaned up my plenum chamber on my intake. and that really help out a lot.
although my CEL was for the #1 cylinder misfire,that code did not go away but my acceleration from a dead stop improved dramatically and even on just normal city driving it really changed after  getting those 2 things done.  my CEL issues went away after i replaced my ECM.
96'''' accord f22b1 vtec
5 sp m/t
aem sri,
228,621 miles
eibach prokit/kyb shocks
ngk iridiumIX plugs and plug wires
magnaflow straight flow muffler 2-1/4" custom catback piping
front strut bar/rear tiebar
(in reply to JimBlake)
Post #: 4
RE: 96 VTEC 4 cyl misfires - 7/23/2008 6:06:37 PM
Hondaccord
Status: offline
I guess that the injectors is the next step. After new plugs, leads, dist cap and buttonthe missing under light load is still there. But that should eliminate the misfire code eventually.
Best method of cleaning the injectors?????????  Thanks
1984 Honda Goldwing
(in reply to trukid21)
Post #: 5
RE: 96 VTEC 4 cyl misfires - 7/25/2008 9:31:40 PM
trukid21
Status: offline
i sent mine out to a injector shop close to my area.got it back within 2 weeks. fairly cheap. they basically overhauled it and place new o-rings and all parts that needed replacing. hope that help.
5 sp m/t
aem sri,
228,621 miles
Post #: 6
RE: 96 VTEC 4 cyl misfires - 7/26/2008 9:53:24 AM
TexasHonda
Status: offline
Make sure your injector oring (injector/manifold) is tight and not leaking air into manifold. This might cause a lean miss. If that doesn''t show anything, suggest swapping injectors to see if problem follows injector. If yes, I would get a used replacement.
See you down the ROW
1994 Accord EX
Post #: 7
Page:   [1]
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
sir_nasty6303
wheelbrokera6276
falkore244355
00accordlx5s3708
deserthonda3500
19accord973013
jimblake2881
smaglik2504
rtexasf2282
yeuemmaimai1822
New Vendors
K&N Engineering, Inc.
