Can I put a set of DSM 450cc injectors on a stock F22A1?
Login | |
Can I put a set of DSM 450cc injectors on a stock F22A1? - 10/31/2007 11:34:13 PM
freemind
I have went with an MSD SS external coil,cap, 9mm wires and NGK platinum plugs and it still missing a little a little. I actually can feel it more now. The engine bogs down alittle when give it throttle at first. I had a newer JDM F22A1 put in about 9 months ago. The guy that did the swap put my old intake, injectors and distributor on the newer engine. It had the slight miss before and still does. I do not want to continue to buy parts without knowing what is really wrong. I'd really appreciate any good advice. -freemind
RE: Can I put a set of DSM 450cc injectors on a stock F... - 11/1/2007 9:01:49 AM
falkore24
What is your A/F ratio with the stock injectors ...... sounds like you're rich causing a choke condition ...... bigger injectors will make this worse and to go that big, you need E-manage to change the duration of the injector pulse. Also, I think platinums are ok with the MSD, but I know that capacitive discharge systems burn the sharpened tips off of iridium plugs. Might be something to check.
_____________________________
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
