Car Does Not Accelerate
Login | |
Car Does Not Accelerate - 11/1/2008 6:40:17 AM
abhijitgp
First of all, I would like to apologize for posting this question here since this forum is for honda accords and my question is regarding Nissan Altima, but experts on this forum have helped me and guided me extensively every time I had any trouble or question regarding my 1994 Honda Accord. I believe that my question is pretty general and you experts will help me solve it. However, I understand if moderators decide to delete this post as irrelevant to the forum. My 1997 nissan Altima (136K miles) seems to have problems accelerating. On regular flat roads, it accelerates perfectly normal upto 60-70mph, however, on roads with a slight up slope or bridges, as I try to accelerate to keep the speed constant or accelerate, the engine begins to rev faster but the car does not accelerate, instead will struggle to speed or slow down a bit. I tried driving up a bridge using cruise control once to see what happens. Turns out the car still struggles a lot and RPM goes very close to red region. I recently had the AutoZone ppl read the Check Engine Light code read for me. It is P0240: Catalyst System Efficiency Below Threshold (Bank 1). I had the muffler and mid-pipe replaced 2 years ago since it had a hole in it, which was making the car run very loud. So is the acceleration problem associated with this error code or it is the transmission or tranny fluid? BTW, a couple years ago, the car stalled often and a mechanic at the Nissan dealership said the fuel pump must have conked out. So it was replaced. Also, during the recent oil change, the air filter also was changed. any ideas appreciated.
_____________________________
1994 Honda Accord EX (5-speed Manual) (>195K miles)
RE: Car Does Not Accelerate - 11/1/2008 9:19:43 AM
cjdm98
Initial throttle problem problem will be the TPS. that controls the throttle body to open to allow air to the motor thus resulting in combustion and acceleration. As far as the OBDII code: It is your O2 sensor bank 1.(connected to the exhaust manifold).
>>Click here to see my Accord<<
RE: Car Does Not Accelerate - 11/1/2008 11:52:42 AM
TexasHonda
Engine speed increasing w/o acceleration suggests a problem w/ torque converter slipping or drive clutches slipping. I assume this is an automatic. Make sure you have adequate fluid in the transmission. I would also check for any OBD2 transmission codes that might be presented. Code P0420 for catalyst system efficiency below threshold will not affect engine performance. It only means the catalytic converter is not performing as designed. good luck
See you down the ROW 1994 Accord EX
RE: Car Does Not Accelerate - 11/3/2008 7:22:13 AM
JimBlake
Severe loss of power together with P0420 - an outside chance of the catalyst plugging up? Dont forget to check the other suggestions, but just add this possibility to the list. At least with Honda, by 1998 the ECU was pretty good at telling the difference between a bad O2 sensor vs a bad catalyst.
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
RE: Car Does Not Accelerate - 11/3/2008 7:55:28 AM
falkore24
Repeating above recommendations, but check the tranny fluid level. If good, your clutch is going bad or if auto, TqCon or frictions are going bad.
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: Car Does Not Accelerate - 11/3/2008 8:42:07 AM
smaglik
assuming its a manual...to check if its tranny...try accelerating hard in too high a gear...say, 5th gear at 35mph. if it does the same thing, i''d say the clutch is slipping.
2002 BMW M3 6MT 1987 BMW 635csi 5MT 1995 Honda Passport LX 4WD 6CYL 5MT
RE: Car Does Not Accelerate - 11/3/2008 8:56:46 AM
abhijitgp
Thanks for all the replies. I will post again with the transmission fluid level. I am sorry I forgot to mention it is an automatic transmission. As far as the code is concerned, will replacing the O2 sensor help or the catalytic converter needs to be replaced? I may put this on the back burner if it is not affecting the engine performance.
RE: Car Does Not Accelerate - 11/3/2008 9:40:04 AM
TexasHonda
The transmission has problems and there may be transmission codes present w/ that level of slippage. Is this by any chance a CVT (continuous variable gear ratio - no shifts). I know Nissan makes these trans, but don''t know much else. P0420 is a difficult problem to resolve. It can be caused by damaged catalytic converter, exhaust system leaks before converter, faulty primary (ahead of converter) O2 sensor, and faulty secondary or rear (aft of converter) sensor. Monitoring the rear O2 sensor performance w/ a good scanner is best way to diagnose problem. Cataltyic converter is too expensive to replace on a guess. good luck
RE: Car Does Not Accelerate - 11/6/2008 12:10:56 PM
abhijitgp
Hello, I checked the transmission fluid today, the level was ok . I noticed that the color of the fluid is red, which means the fluid has not gone bad, right? Also, I might have edit my original question a bit. I noticed carefully the way engine responds to acceleration. The car has hard time picking up beyond 50mph. When press down on the pedal, the engine roars louder, with RPM around 3-3.5K. It roars so much that I feel I am hurting the engine, but if I keep pedal pressed down, it will eventually accelerate beyond 65-70MPH, but takes about 30-45 seconds or maybe more, to get to that speed. So basically the response time is really long. For a car that has 2.4L engine, 135K miles and regular oil change, this struggle to speed up seems odd. What is the next thing I should look for? thanks
RE: Car Does Not Accelerate - 11/6/2008 1:16:25 PM
PAhonda
Are the spark plugs and air filter in good shape? Are there any other maintenance items due for replacement changed like an external fuel filter? A clogged catalytic converter sounds like a possibility. A quick check of the catalytic converter is to hit it with the handle of a screw driver and listen for rattling (broken pieces of the catalyst). Can anyone else suggest other simple tests to verify that the catalytic converter is not clogged?
1995 Accord EX MT
RE: Car Does Not Accelerate - 11/6/2008 1:34:32 PM
cjdm98
A clogged cat is a possibility PA, but i doubt its bad... to actually diagnose a cat failure involves removing it and see how the engine behaves then.
RE: Car Does Not Accelerate - 11/6/2008 7:27:31 PM
abhijitgp
The air filter was replaced a month ago when I had the oil change done. as for the spark plugs, they have not been replaced in past 3 years that I have had the car, but if one of the plugs fails, will the engine work at all? The way engine is running, it does not feel as if is is misfiring, it just struggles to accelerate. The fuel filter has not been replaced either, in the past 3 years unless Nissan dealership replace it when they replaced the fuel pump (pardon my ignorance). Is there any easy way to determine if there is a problem with the transmission itself, like by shifting to D2 while driving uphill or something?
RE: Car Does Not Accelerate - 11/7/2008 4:24:32 PM
TexasHonda
If rpm increases significantly w/o acceleration or increase in speed, the transmission has a problem. From your description, the transmission is slipping badly. good luck
RE: Car Does Not Accelerate - 11/7/2008 5:37:15 PM
PAhonda
The plugs could be worn out and not giving you a strong spark. Here is a link for the owners manual: http://www.nissanextendedwarranty.com/owners-manual/nissan_owner_manuals.html It says to replace them 30k/2yrs, so you are past due. This is something that needs to be done and is a cheap fix compared to having the tranny diagnosed.
1995 Accord EX MT
RE: Car Does Not Accelerate - 11/9/2008 2:20:25 PM
JimBlake
quote:
ORIGINAL: TexasHonda If rpm increases significantly w/o acceleration or increase in speed, the transmission has a problem. From your description, the transmission is slipping badly. good luck YES. After re-reading the original post, I gotta agree with this. Bad plugs or a plugged cat would cause the engine to lose power. In that case it WOULD NOT rev high. Revving high indicates the engine is making the power, but the tranny cant deliver it to the axles. With a manual tranny, that means you simply need a new clutch. With an automatic, ??? If it was a 98-02 Honda automatic, the tranny would be near-death.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
