Cause of sticking heater temperature control
  Printable Version
Honda Accord Forum >> General >> Do-It-Yourself Section >> Cause of sticking heater temperature control Page: [1]
Login
Cause of sticking heater temperature control - 2/22/2007 5:41:33 PM
Tony1M
Score: 0
Status: offline
I just succesfully replaced the blower motor in our 1992 Accord LX 4AT, no AC, no power anything.
While I had the duct and fan housing removed I discoverd the ulitimate cause of the sticking heater temperature control slider that has caused great trouble and expense to many owners of this generation of Accord.
As I moved the temperature sliding lever back and forth, I could easily see that the foam gasket of the forward-most flapper-door sticks terribly to its plastic seat on the heater-core housing.
I had to pull pretty hard on that front flapper to finally pry it loose from the gasket.  Sticky stuff was on the surface of the foam gasket, as well as on the plastic surface where it seated and sealed.
This is the ultimate cause of probably tens of thousands of repeatedly stuck and broken temperature slider controls on these cars.
What I believe has happened from Day 1 is that this chemically-improper foam gasket gets sticky from the heat of the heater-core sitting mere inches away.  Then, when the car is turned off, this sticky material hardens like a glue between the foam gasket and the plastic.
During the summer, there's not too much trouble, but during cold weather it is almost impossible for the cable to exert enough force to break loose that stuck flapper.
When that cable fails, it's an extemely expensive thing to replace. We had ours replaced shortly after our warranty expired, and the bloody thing broke again within a year. Probably Hoda did not have a clue why this was happening.
I scraped off the sticky stuff on the plastic and removed as much of the sticky surface of the foam gasket as I could.  I then considered what to do to keep those surfaces unstuck, so I coated the gasket itself, and the plastic surface it seals against, with a thick layer of silicone grease.  Hopefully this will keep those surfaces lubricated enough so that when the gasket softens again it will have nothing to stick to.
If this doesn't work over the long haul, I think the thing to do would be to cut some one-side-sticky paper to the same dimension as the gasket and stick it to the gasket with the not-sticky side facing the sealing surface.  That should be the final solution to the problem, and I'm kinda sorry that I thought of it only after getting the thing re-assembled.
_____________________________
Tony
1992 Accord LX, 4AT, 4 dr, no AC, no power anything
Post #: 1
RE: Cause of sticking heater temperature control - 2/22/2007 6:11:03 PM
sir_nasty
Score: 0
Status: offline
how difficult is it to repair that issue? can you do it with duct still in?  care to do another one of your fantastic write-ups for our DIY section??
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Quote: Life''''s great but it''''s not all beer and skittles
(in reply to Tony1M)
Post #: 2
RE: Cause of sticking heater temperature control - 2/22/2007 6:25:00 PM
Tony1M
Score: 0
Status: offline
That intermediate white duct has to be removed to get at the flapper and its gasket.  It's not too difficult to remove it, but it's more difficult to re-install it.  That bloody metal strip that joins the duct to the fan housing takes some fiddling with to finally get its threaded holes lined up with the correspoinding holes in the plastic duct and fan housing.
If the silicone grease doesn't fix it for good on our car, I'll take some pictures of the "final solution".
Honda should have discovered this problem, and solved it, in 1992 or 1993.  Dealing with that sticky gasket should have gone part and parcel with replacing the slider cable.  Not dealing with the gasket almost certainly means that any replacemnet cable will also fail one winter season down the road.  Nobody in their right mind is going to give Honda ANOTHER $400 to NOT fix the same problem again.
Tony
(in reply to sir_nasty)
Post #: 3
RE: Cause of sticking heater temperature control - 2/22/2007 9:46:41 PM
ArcticHonda
Score: 0
Status: offline
Are you talking about the slider controls on DX models or the Round dial type like the one below - or both?
Thumbnail Image
Attachment (1)
Post #: 4
RE: Cause of sticking heater temperature control - 2/22/2007 10:36:10 PM
hondadude
Forum Monitor
Score: 0
Status: online
ZING..... there it went ArcticHonda, right over your head
This post was made by a REAL Hondadude, not the wanna be Honda_Dude
85 Yota pickup 235k miles "never say die" 22r engine.
92 Acura Legend 70k miles. Wife lets me drive it for oil changes.
(in reply to ArcticHonda)
Post #: 5
RE: Cause of sticking heater temperature control - 2/22/2007 10:43:05 PM
Tony1M
Score: 0
Status: offline
I'm talking about the slider for heater air temperature control.  It's the bottom slider in this picture:
When the slider has been at the hot end (all the way to the right) for a bit of time, it is almost impossible to then move it more than about 1/4 of the way to the left - toward cooler air.  If you force it, it will break the cable housing, and then you're either in for some expensive repair, or you have to unhook the cable where it attaches to the valve/flapper mechaism near the floor under the center of the dash.  In the latter case, you're then in "manual" mode and you have to reach under there with your hand and manipulate things to get the temperature you want.  My wife and I did that for many years.
Tony
Post #: 6
RE: Cause of sticking heater temperature control - 3/21/2007 10:01:49 PM
rcy
Score: 0
Status: offline
I have this same problem with my 91 Accord EX-R, which is the push button mode, with dials for fan speed and temp.  I've noticed when the car heats up, the door eventually moves fine.  In my car, it sticks in full cold.  I guess this door let's air flow over the heater core?  I don't think I have a coolant valve - I think hot coolant always flows through the heater core, and the door blends outside air in to control the temperature.
Post #: 7
RE: Cause of sticking heater temperature control - 3/22/2007 1:24:39 PM
Tony1M
Score: 0
Status: offline
Check under the hood near the fire wall - where the two heater-core coolant hoses penetrate the fire wall.  I think you'll see a valve on one of those hoses.  Make sure it opens and closes fully when you operate your temperature contol.
Tony
(in reply to rcy)
Post #: 8
RE: Cause of sticking heater temperature control - 1/5/2008 9:47:18 AM
Tony1M
Score: 0
Status: offline
Just an update because of a new thread about this subject.
Our temperature slider has been working just great this winter.  It's very nice to be able to adjust the temperature of in-coming air without having to be a contortionist.
Tony
Post #: 9
RE: Cause of sticking heater temperature control - 1/5/2008 10:01:56 AM
sir_nasty
Score: 0
Status: offline
Did we ever sticky a write-up on this in the DIY section or should I move this one over?
Post #: 10
RE: Cause of sticking heater temperature control - 1/5/2008 10:22:57 AM
Tony1M
Score: 0
Status: offline
What would be nice would be, as you suggested in an earlier post, to have photos to accompany the steps of the job. I could have killed two birds (blower motor replacement and testing, and flapper troubleshoot and repair) with one stone, but although I like the HAF very much, I don't like it enough to go through the job again just to take photos!  (Like I've said on more than a couple of occasions, people should take and post more photos of the various jobs they perform after getting advice on them here on the HAF.  That would be a tremendous aid to others and probably the site would be much more popular as a result.)
However, even though there are no photos of this job, I'm sure our car is not alone with this nag of a problem, so I think there should at least be some mention of it in a prominent place.
(Literally every time I operate that slider I'm reminded of what we had to go through for years without being able to use it.  My overall attitude toward the car changed remakably after I finally got it fixed.)
Tony
Post #: 11
Page:   [1]
Honda Accord >> General >> Do-It-Yourself Section
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7083
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
