Check Engine (8 flashes)
Login | |
Check Engine (8 flashes) - 7/9/2007 4:59:13 PM
biz_accord
Hey guys did a search and to no avail I write this post, hope ya'll can help. Car: 97 Accord SE diag: -So I checked using the paperclip method I got 8 flashes. -Poked around my distributer and the wires that lead to spark plugs -discoverd that the fifth wire (non spark plug wire) was broken at the plug end. - I attempted to solder it -reset ecu -stayed off for about 3 days - back on again giving me 8 flashes with check engine. What are the possibilities here? I will replace that broken wire and see if it makes a difference. If not according to the OBD trouble codes it can be the following: P1359 8 CKP/TDC Sensor Connector Disconnection P1361 8 TDC Sensor Intermittent Interruption P1362 8 TDC Sensor No Signal if it is any of the above do I just go ahead and change the whole distributer??? also, Can it also be this???: P0401 80 EGR Insufficient Flow Detected any help is apperciated thanks
RE: Check Engine (8 flashes) - 7/10/2007 5:28:30 AM
JimBlake
First you have to decide between code 8 (8 short flashes) vs. code 80 (8 long). Unplug your intake air temperature sensor (IAT). That should throw a code 10 which is one long flash. That'll help you recognize the difference between a long flash vs. a short flash. Running with that unplugged for a minute is pretty harmless to the engine. Or take it to AutoZone & let them read the code with their scanner to give you the more specific 4-digit code. I think in '97 the TDC sensor is in the distributor, and it's not replaceable by itself. So if you can't find a loose wire to blame it on, you need a new distributor.
_____________________________
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
RE: Check Engine (8 flashes) - 7/10/2007 8:05:06 AM
sir_nasty
If it is a TDC issue and the 5th wire you are refering to is your Coil wire there is a slim possibility that it's arcing intermitently and throwning that code... Make sure you have good plugs (NGK) and if that wire is the coil wire and it's bad I'd replace the whole set then reset the ECU and see what happens
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''''s great but it''''s not all beer and skittles
RE: Check Engine (8 flashes) - 7/10/2007 10:48:34 AM
JimBlake
Yeah, that's a good idea. Get rid of a potentially arcing bad wire first to see whether that caused it all from the beginning. Soldering isn't a good way to repair those secondary wires. More likely the spark is 'leaking' thru the insulation and heating (soldering) will just do more damage to the insulation. Cams or timing belt should have caused completely different problems. Don't mess with them (yet).
RE: Check Engine (8 flashes) - 7/10/2007 1:48:08 PM
biz_accord
Cool, i'll keep you updated on the progress. thanks
RE: Check Engine (8 flashes) - 7/17/2007 2:58:08 PM
biz_accord
Update: Changed the faulty coil wire, and replaced the spark plugs... Results: Engine light came back on... 8 flashes... TDC error Any more suggestions??
RE: Check Engine (8 flashes) - 7/17/2007 9:30:51 PM
JimBlake
First, go back & check the difference between long & short flashes. Or go to AZ & get the Pnnnn code. Don't go wild with distributors until you know whether it's the EGR in the first place. Well, you've ruled out simple interference from a bad secondary wire, and the new plugs are probably not related to the error. Those would have been nice things to do anyway. Check to rule out loose/corroded connections at the distributor wiring harness. I don't have a '97 wiring diagram to say what color is the TDC sensor. The possibility of a bad TDC sensor gets more likely as you rule out the easier stuff. Check the resistance, but someone will have to chime in to say which wires & what's the correct resistance. Got any red/brown dust inside the distributor? Can't get that TDC sensor separately; you have to get a new distributor.
< Message edited by JimBlake -- 7/17/2007 9:34:54 PM >
RE: Check Engine (8 flashes) - 7/18/2007 8:29:53 AM
biz_accord
Thanks again Jim. Done: checked the wiring harness at dist. all seems to be in tip top shape. Even inside of dist., it was clean. So yes, hopefully soeone can chime in about the wiring and resitance, I think i will go ahead and change distributor and put in a complete wire set.
RE: Check Engine (8 flashes) - 7/18/2007 9:53:59 AM
JimBlake
Dont forget to rule out the EGR code just in case it's really been a code 80 all along. A new distributor is kinda pricey if you don't really know that's it. Maybe some download pdf file of a Helm repair manual? I KNOW the wiring and correct resistance is given in that book.
RE: Check Engine (8 flashes) - 7/18/2007 10:07:36 AM
biz_accord
Ya I am familiar with the distributer and its components. And yes it is pricey. As for the EGR what does that consists of? I have the manual (94 accord) and I have not seen the code for 80 nor the diagnostic.
RE: Check Engine (8 flashes) - 7/18/2007 11:33:06 AM
00AccordLX5spd
Did you replace all the wires or just the one wire that was faulty? Before blowing my cash on a new distributor I would get a entire set of new plug wires and install them. Is anything amiss with the engine running? Or is it just a Check Engine Light? Go to AutoZone and ask them to hook up their OBDII code reader to your car and give you the code. They probably won't know where to hook it up (I had to show them on my '95). The connector is behind the ashtray. The ashtray pulls right out and there is a plug there. Get the code from them & post it here. Oh, by the way, what kind of plugs did you use? Please don't tell me you used Bosch!
2000 Accord LX Sedan F23A1 5spd -Short Shift Adapter -eBay SRI w/ K&N 1995 Accord V6 Sedan AT - AKA "the money pit" 1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
RE: Check Engine (8 flashes) - 7/18/2007 11:55:53 AM
biz_accord
in the process of getting new wires....we don't have auto zone in quebec, but I know what you mean and can get the code from any garage anyways. But won't it give me the same results as in the 2 pin method? I will do as Jim said and check reisitance first. that can be very usufull instead of blind shooting the wires.
RE: Check Engine (8 flashes) - 7/18/2007 12:14:36 PM
00AccordLX5spd
It will give you a more exact code than the "8" or "80" I believe. It will be a four digit code starting with a "P."
RE: Check Engine (8 flashes) - 7/18/2007 1:25:54 PM
JimBlake
quote:
ORIGINAL: biz_accord in the process of getting new wires....we don't have auto zone in quebec, but I know what you mean and can get the code from any garage anyways. Canadian Tire or ??? Wherever you can borrow an OBD-2 code reader. The question in MY little mind is whether you recognize the difference between 8 short flashes vs 8 long flashes (code 8 vs code 80). EGR is Exhaust Gas Recirculation. Probably Canada cars have it too, but it's always good to know what part of the world you're talking about. Little passageways in the intake manifold that get plugged up with carbon crust.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
