Check engine light is on
  Printable Version
Honda Accord Forums >> General >> Do-It-Yourself Section >> DIY Requests >> Check engine light is on Page: [1]
Login
Check engine light is on - 2/12/2008 7:58:18 PM
jmehaff
Score: 0
Status: offline
Just replaced the timing belt, water pump and seals on my son's 97 Accord LX V6.  Before disassembly, ensured TDC, during replacement ensured that nothing was disturbed, after reassembly started the vehicle, appeared to run fine and then shortly afterwards the check engine light came on.  While engine was running, there were no metal to metal contact sounds, no whinning belts, no other indicators.  Any suggestions would be greatly appreciated.
Respectfully,
Jeff
Post #: 1
RE: Check engine light is on - 2/15/2008 9:52:13 AM
00AccordLX5spd
Score: 0
Status: offline
Take it to AutoZone or Advance Auto Parts.  They will read your OBDII trouble codes for free.  the OBDII service connector is located behind the ash tray.  Simple pull backwards on the ash tray to remove it and expose the connector.  All they need to do is hook up their code reader.
Please post the exact code number here.  It will look like this "P0123."  Do NOT listen to the explanation they give you for why the code is shown.  They are usually trying to sell you parts when they do that.  Many times their explanations are dead wrong on a honda, however, the code is correct.
_____________________________
2000 Accord LX Sedan F23A1 5spd
-Short Shift Adapter
-eBay SRI w/ K&N
1995 Accord V6 Sedan AT - AKA "the money pit"
1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
(in reply to jmehaff)
Post #: 2
RE: Check engine light is on - 2/16/2008 10:07:21 AM
jmehaff
Score: 0
Status: offline
Was finally able to make it to autozone, had the code read, P1361, the definition spit out was "Intermittent Interruption in TDC 1 Sensor Circuit."  I certainly appreciate your assistance.
Respectfully,
Jeff
(in reply to 00AccordLX5spd)
Post #: 3
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7083
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3443
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
