Clutch feels totally different, what could be the problem?
  Printable Version
Honda Accord >> General >> General Tech Help >> Clutch feels totally different, what could be the problem? Page: [1] 2   next >   >>
Login
Clutch feels totally different, what could be the problem? - 1/2/2008 4:29:01 PM
Buktheng
Status: offline
So last Friday, I parked the car after driving home from work and didn't drive it pretty much all weekend until Monday I think.  I start up the car to move it and my clutch feels totally different.  I feel no pressure at all pushing down on it, until about half way close to the ground.  I can literally just push it down without any pressure at all and it'll come right back up like a bouncy ball.
Now the clutch literally engages like about two centimeters off the ground.  It definitely wasn't like this before and it's getting me worried because I don't want to end up on the side of the road because my clutch dies out or something.  The  clutch isn't slipping at all so I don't know could be the problem.  Let me know what you guys think, thanks!
EDIT -
So I finally got the new master clutch cylinder in and now I have no pressure on the clutch at all. I tried bleeding the clutch but it doesn't seem to be working. I had my brother push on the clutch five times then hold it in then I would loosen the bleed bolt and I would only see the fluid coming out. Is the car suppose to be on when you're doing this? Am I doing something wrong to not get any pressure on my clutch?
< Message edited by Buktheng -- 1/5/2008 12:09:12 PM >
_____________________________
95 Accord EX Coupe - My DD
Bone Stock
Post #: 1
RE: Clutch feels totally different, what could be the p... - 1/2/2008 4:57:26 PM
cheggie
Status: offline
You need to check the clutch master and slave cylinders. A leaking seal can cause the pedal to go "to the floor." You can see the slave cylinder, it's right below the starter. It looks like a cast iron twinkie with a rubber bellows on the end. It's easy to see when it leaks - pull back the boot and look for the creamy filling, er leaking hydraulic fluid. The master cylinder is better protected, but if it leaks it might dribble into the driver's side toeboard. You can replace each cylinder separately, or get a reseal kit for them. I had very good luck resealing my slave cylinder, but YMMV. The seal kit was cheap - $14.00. The cylinders are more like 60-75 each.
That it failed so suddenly makes me think it has to be a seal that finally gave up. I'd look closely at the slave cylinder, because it's "out there in the elements."
1991 Honda Accord LX 5 spd
178,431
(in reply to Buktheng)
Post #: 2
RE: Clutch feels totally different, what could be the p... - 1/2/2008 5:05:18 PM
HondatechAV6
Status: offline
good points. start with checking the clutch master cylinder fluid level.
Honda Platinum Certified - A.S.E. Master Tech
I'm just a nice guy
(in reply to cheggie)
Post #: 3
RE: Clutch feels totally different, what could be the p... - 1/2/2008 5:28:48 PM
Buktheng
Status: offline
Is there a DIY guide that I can read to replace the cylinders?
Bone Stock
(in reply to HondatechAV6)
Post #: 4
RE: Clutch feels totally different, what could be the p... - 1/2/2008 6:52:58 PM
HondatechAV6
Status: offline
http://www.verzend.be/v/4412751/AC9495A12005A.pdf.html
http://www.verzend.be/v/6627943/AC9495A12006A.pdf.html
I'm just a nice guy
Post #: 5
RE: Clutch feels totally different, what could be the p... - 1/3/2008 7:37:49 AM
Buktheng
Status: offline
This morning when I started up the car, I can't shift into gear!  It seems that when the car is off, I can shift into gear but when I turn on the car, I can't shift into gear.  Do you think changing the slave or master cylinder will fix the problem?
Bone Stock
Post #: 6
RE: Clutch feels totally different, what could be the p... - 1/3/2008 7:39:34 AM
falkore24
Status: offline
falkore24's photo gallery
That sounds like a good assumption ..... did you ever check the fluid level???
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 7
RE: Clutch feels totally different, what could be the p... - 1/3/2008 11:43:33 AM
Buktheng
Status: offline
I bought a new master clutch cylinder, now I'm having a hard time unscrewing the clutch pipe.  I put some WD-4 on it and I'm still having a hard time unscrewing it.  What did you guys use to loosen it up?  Its pissing me off I can't get it loosen.
Bone Stock
(in reply to falkore24)
Post #: 8
RE: Clutch feels totally different, what could be the p... - 1/3/2008 12:04:30 PM
falkore24
Status: offline
is the old one bad?
2000 V6-AT (RIP 3G)
Post #: 9
RE: Clutch feels totally different, what could be the p... - 1/3/2008 12:26:37 PM
Buktheng
Status: offline
Quick question, the master cylinder on the car is totally different then the one that was purchased.  The one I bought look like this http://www.carpartswholesale.com/wholesale/clutch/honda-accord-9472315.html  but the one on the car has a spot for the reservoir.  Is this going to be a problem?
Bone Stock
Post #: 10
RE: Clutch feels totally different, what could be the p... - 1/3/2008 12:54:43 PM
00AccordLX5spd
Status: offline
Doesn't your old reservoir attach to the top of the new one?
2000 Accord LX Sedan F23A1 5spd
-Short Shift Adapter
-eBay SRI w/ K&N
1995 Accord V6 Sedan AT - AKA "the money pit"
1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
Post #: 11
RE: Clutch feels totally different, what could be the p... - 1/3/2008 2:28:35 PM
Buktheng
Status: offline
Well, I finally got everything off.  According to the manual, when I pull out the master clutch cylinder, the whole piece is suppose to come out.  But the problem I'm having now is, there's this pole sticking out that won't come out and I'm wondering how the other end of it is suppose to come out since the whole in the middle is small.  Here's a picture, let me know what I'm suppose to do cause I'm pretty stumped.
See those three rods sticking out?  How am I suppose to get that out?  The two threaded rods on each side, I need to get those out so I can put in the new master clutch cylinder because there are two threaded rods already on the clutch cylinder.
Bone Stock
(in reply to 00AccordLX5spd)
Post #: 12
RE: Clutch feels totally different, what could be the p... - 1/3/2008 4:36:45 PM
HondatechAV6
Status: offline
my friend...you pulled off the brake master cylinder. this is the part you want to pull off your car:
see this pic?
the arrow points to the clutch master cylinder reservoir, which is connected to the clutch master cylinder. you didn't need to remove the brake master cylinder to remove it.
did you read the pdf files i posted?
I'm just a nice guy
Post #: 13
RE: Clutch feels totally different, what could be the p... - 1/3/2008 4:51:22 PM
TexasHonda
Status: offline
Well, good news is it looks like the brake master cylinder may have been leaking a bit also.
The dribble line from the clutch MC looks just like the one I had on my daughter's 97 Acura 2.2CL (essentially an Accord). It made a world of difference in clutch performance, which had gradually deteriorated until the clutch pedal fell to the floor.
Removing the hard line to the MC is a challenge due to space limitations. I found I could not use a 12mm flare tubing wrench which is correct tool for the tubing nut due to space. However, the nut was loose enough to allow removal w/ a 12mm open-end. Hopefully your's will be also. I found that removing the brake booster vacuum line provided some additional room to work on the clutch MC.
See you down the ROW
1994 Accord EX
Post #: 14
RE: Clutch feels totally different, what could be the p... - 1/3/2008 5:06:01 PM
Buktheng
Status: offline
It seems now I have a another major problem.  I removed the two nuts from the clutch master cylinder before removing the clutch pipe and the reservoir hose.  I was able to get the reservoir hose loose and off but there's no way I was able to get the clutch pipe loosen so I tried pulling out the clutch master cylinder hoping I was able to get it out enough so I can loosen the clutch pipe.  Now the problem is no matter what I do, I can't get the freaking thing out at all!  No matter what angle I do, it hits something and blocks the cylinder from coming out.
I'm out of ideas on what to do because I was trying to put it back in but I can't even do that because it won't turn at all to let me put the left screw in first.  It won't turn at all!  I'm thinking it's because of the clutch pipe which is killing me!  Here's a pic.
You guys having any idea on what I can do?  I'm practically just stripping the clutch pipe trying to loosen it with a wrench.
Bone Stock
(in reply to TexasHonda)
Post #: 15
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7083
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
