Cracked Block?
Login | |
Cracked Block? - 11/9/2008 9:09:50 AM
delsen66
Hello, I have a 1993 Honda Accord LX. It is leaking oil on the back side of the engine and dripping down to the exhaust. I had a mechanic look at it and he said it was a cracked block. The car runs fine in every way and shows no signs of antifreeze leaking into the oil. Is it possible to have a cracked block and only have oil seeping out from the crack? Also, is the oil dripping on to the exhaust a potential fire hazard? Meaning, will I be driving along and suddenly have the car burst into flames? Lastly, if it is a cracked block, is there a way of fixing it...such as an aluminum weld? Thanks, Dan Duluth, MN
