Crank Pulley bolt
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> Crank Pulley bolt Page: [1]
Login
Crank Pulley bolt - 11/19/2008 2:08:12 PM
swordfish7769
Status: offline
Since the search isn''t working I figure I will ask.  What have you guys been doing to get your crank pulley bolt off to do the timing belt?  I tried a 1/2" impact, but I am affraid I will have to try and find a 3/4" to borrow.  Any insight on this?  I appreciate the help!
Swordfish7769
_____________________________
'97 Accord EX 5 sp. 4 dr. 172K miles Stock
Post #: 1
RE: Crank Pulley bolt - 11/19/2008 2:11:19 PM
falkore24
Status: offline
falkore24's photo gallery
You need a gun with about 500 ft.lbs. of torque.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to swordfish7769)
Post #: 2
RE: Crank Pulley bolt - 11/19/2008 2:13:24 PM
finch13
Status: offline
Here''s a few:
http://www.hondaaccordforum.com/archive/threads/crankshaft-pulley-bolt-removal-ideas-32138-1.html
Use the search link below if you want more.
USE ME TO SEARCH HAF
PWOTY 2008!
Post #: 3
RE: Crank Pulley bolt - 11/19/2008 3:30:19 PM
hondadude
Forum Monitor
Status: online
What kind of impact did you try?
TOP TECH TIP OF THE DAY
Hydrolock the impact;
Hold the trigger on the impact, drizzle in about 1/8 cup of ATF or air tool oil into the air fitting.
You should be able to hear the oil slosh when spinning the anvil by hand.
Turn the compressor to max pressure and biggest diameter air hoses/fittings.
[air flow is as important as pressure]
Either the crank bolt will come loose or the impact will snap the shaft on the rotor.
< Message edited by hondadude -- 11/19/2008 3:31:08 PM >
This post was made by a REAL Hondadude, not the wanna be Honda_Dude
85 Yota pickup 235k miles "never say die" 22r engine.
92 Acura Legend 70k miles. Wife lets me drive it for oil changes.
Post #: 4
RE: Crank Pulley bolt - 11/19/2008 3:52:09 PM
falkore24
Status: offline
Hmmm .... I prefer the Ingersol Rand 600 ft.lb. double hammer method
2000 V6-AT (RIP 3G)
(in reply to hondadude)
Post #: 5
RE: Crank Pulley bolt - 11/19/2008 4:15:38 PM
PAhonda
Status: offline
You have a few options to loosen that PIA bolt.
1.  Call a local honda dealership or mechanic and ask them to loosen the bolt then tighten it up.  They shouldn''t charge too much to do this.
2.  As hondadude mentioned, get the most out of your impact wrench.
3.  Use leverage.  I bought the crankshaft holding tool and used and extension to wedge the holding tool against the subframe.  I put my doughnut on the driver''s side tire and turned the wheel all the way to the left to access that bolt.  (I didn''t want to pull my car off my jackstand).  I used a long extension (24") to get my breaker bar outside of the wheel well.  I rested the end of the extension on my jackstand to keep the extension perpendicular to the crank bolt.  I used a breaker bar with a 5ft piece of pipe over it to get leverage.  I had my foot on the extension at the jackstand.  I started the breaker bar at the 3 o''clock and the bolt broke loose at around 10 o''clock.  It took a lot of force to get that bolt to loosen.
1995 Accord EX MT
Post #: 6
RE: Crank Pulley bolt - 11/19/2008 4:19:12 PM
falkore24
Status: offline
It took 5 seconds with the can and gun that are in this pic.
2000 V6-AT (RIP 3G)
(in reply to PAhonda)
Post #: 7
RE: Crank Pulley bolt - 11/19/2008 5:01:00 PM
kris_loehr
Status: offline
I purchase the tool for the crank from Amazon which was the best price and quick then let the tool wedge itself up again the inner fender. Then I put a ½ driver deep socket on my breaker bar handle along with a long extension. I didn’t have a pipe at the time. It worked well and without busted knuckles or %$##%
(in reply to falkore24)
Post #: 8
RE: Crank Pulley bolt - 11/19/2008 5:06:06 PM
kris_loehr
Status: offline
This question is a little off topic but swordfish7769 may be doing the timing belt. The cranking the engine counterclockwise to set belt Tension, is this from looking at front of the engine. If so I wonder if this is why Honda has the crank bolt torque so high.
< Message edited by kris_loehr -- 11/19/2008 5:08:08 PM >
(in reply to kris_loehr)
Post #: 9
RE: Crank Pulley bolt - 11/20/2008 5:24:55 AM
swordfish7769
Status: offline
Thank you all for your input.  Yes I am doing the timing belt and this is the point that always gets me.  I will try your suggestions.  Hopefully I can rent a bigger impact from one of the auto stores.  I think mine is putting out around 300/400 lb/ft so that won''t do.  Thanks again!
swordfish7769
Post #: 10
RE: Crank Pulley bolt - 11/20/2008 5:53:06 AM
falkore24
Status: offline
^^^  It might work if it really puts out that much torque.
2000 V6-AT (RIP 3G)
Post #: 11
RE: Crank Pulley bolt - 11/21/2008 5:31:03 PM
JimBlake
Status: offline
Dont use any extensions - they reduce the torque that actually gets to the bolt.  In fact, dont use a deep socket either.  You might need to remove the plastic inner fender.
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
Post #: 12
RE: Crank Pulley bolt - 11/21/2008 8:44:15 PM
TexasHonda
Status: offline
A try w/ your impact hammer is worth a chance. It may work.
I''ve found that lubing the bolt w/ anti-sieze on threads and between washer and bolt cap eases removal next time.
See you down the ROW
1994 Accord EX
(in reply to JimBlake)
Post #: 13
Page:   [1]
Honda Accord >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7083
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
