deserthonda
Score: 0 Joined: 12/3/2005 Status: offline
for such an alder car if you can find a used switch go with it...... To replace it,,,,,,,,first off, make sure wheels are straight, stweering wheel straight, .. remove the center cap off the steering wheel, remove the 19mm nut off the steering wheel , disconnect the cruise control plug, pull off the steering wheel, remove the upper and lower covers, ,remove the 4 little screws for the cruise ring, ( move to the side ) remove the screws holding the combo switch in place, you might have to move the blinker switch up and down to easier get to the screws ,,disconnect the plugs, they are under the dash,, just follow them from the combo switch, reconnect in reverse order
_____________________________
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
