Front 92 suspension
Login | |
Front 92 suspension - 4/22/2008 10:13:16 AM
Vancefish
I have a 92 Accord 2 door Auto I bought for $500. Although it has 270k miles it runs great and shifts great. I replaced the timing belt and that metal coolant pipe as well as the exahst system, then started on the suspension. First off, everything was bad. I purchased a cheap e-bay kit and a few bushings that didn't even exist. Then got an allignment. It was better however over speed bumps the front would clunck. So I relaced the strut bushings in and out. As well as the tension rod bushings. This solved the clunck. However the cheap ball joints are worn out again from all the stresses of the other issues. I have a mechanic friend who tells me I should use only Honda parts, Although the lower ball joint is cheap at $28. The uppers are $190 each. I can find cheaper on the market but what about quality on these parts. Replacing this stuff is a real pain for me and I'm far from rich. So can anyone aim me toword a cheaper set of these that will last more then a few months?
