Fuel Additives
Login | |
Fuel Additives - 10/30/2006 4:11:57 PM
abhijitgp
hi, For 1994 Honda Accord EX, with 189K miles on it, what kind of fuel additives can I use for better performance? Thanks
RE: Fuel Additives - 10/30/2006 4:22:55 PM
sir_nasty
I don't know that much of anything will give you better performance per say but you could try octane booster.... I highly doubt you'll notice a difference with just that but you could also get Nitrous and that's a fuel additive system that would increase your performance
_____________________________
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''''s great but it''''s not all beer and skittles
RE: Fuel Additives - 10/31/2006 2:07:16 PM
abhijitgp
What about adding some some fuel injector cleaners and any such stuff? Does it really work? Coz I heard that such things screw up the engine and certain vital parts/ I guess, what I want to know is what kinda such products are safe and tes effective? Thanks
RE: Fuel Additives - 10/31/2006 2:43:20 PM
RTexasF
Forum Monitor Posts: 2357
Joined: 11/16/2004 From: Brownsville, TX Status: offline
Chevron Techron works well and is safe providing you don't overdose.
''''04 2.4l 5M EX Sedan Neuspeed short shift kit V-6 6 speed front strut/firewall brace 17mm rear anti sway bar AEM Shorty DC Sports SS Header Kicker Speakers JL Audio Clean Sweep JL Audio Amp 200W Bazooka sub V-6 OEM 7 spoke alloys
RE: Fuel Additives - 10/31/2006 2:57:25 PM
sir_nasty
stick with name brand stuff like Chevron and you should be fine, just pay attention to the limits the bottle says.... just like RTexasF said no problems as long as you don't overdo it
RE: Fuel Additives - 10/31/2006 8:54:02 PM
YeuEmMaiMai
sea foam is an excellent product for cleaning intakes and carbon deposits along as fuel injectors
Jesus is Salvation White 2002 Acura CL type S. 68K and change Criminals thrive upon the intolerence of society''s understanding.....and political correctness
RE: Fuel Additives - 11/2/2006 10:18:22 AM
abhijitgp
I read about the methods to use seam foam in General Tech Help area, but seemed like the instructions were not clear enough. Can anyone give step-by-step instructions once again? Also, is it true that a paste of baking soda + water, when applied to the rusted area takes the rust away? How long should u leave the paste on the rusted area and how do u take it off atfer the job is done? Can I apply it to the battery terminals as well? THanks
RE: Fuel Additives - 11/2/2006 11:46:14 AM
RTexasF
I've never heard of it removing rust but it will clean the crud off of the positive battery terminal.
RE: Fuel Additives - 11/2/2006 6:44:25 PM
mbo1985
I seafoam my motors by feeding approx 1/3 of the bottle through the brake vac line with the engine running. After the motor sucks the sea foam in, it will probably be ready to quit. If it died before you got to get all (1/3 of the bottle) of the fluid in, have someone start it while you help feed the rest of the fluid in. Then I usually let the motor sit for 5 minutes or so. Then, come back and start it up. Don't use the gas pedal. The engine may be hard to start, but that's ok. Once it gets running just let it idle for 10 minutes or so. There will be a ton of smoke, and that's totally normal. After letting it idle, you may want to drive around the block a few times to make sure any excess sea foam is out of the engine. as for the rest of the bottle, I put the other 1/3 in the crankcase the rest in the fuel tank. You don't need to do anything special there. And don't foget to put that brake vac line back on!!
1996 Accord LX Coupe Suspension Techniques Springs KYB AGX Struts Turbocharged
