Fuel Filter and EGR Valve Replacement
Login | |
Fuel Filter and EGR Valve Replacement - 5/4/2005 12:00:44 PM
Buckeye
All, Just found the forum this morning, and already enjoying all the great information. I have a 96 Accord EX 4-cylinder and like to do as much work myself as possible (oil changes, etc). I'm not an accomplished mechanic, but have tools and am willing to give things a shot if it's not too difficult. I'm looking at replacing my fuel filter and EGR valve, but don't know how difficult it is. Are these jobs relatively straightforward, or something to be left to a dealer for all but the diehard mechanics among us ? I don't believe these have been replaced in awhile, are they critical to be changes at certain intervals ? Did not see these issues mentioned on the forums in past posts, hence my writing this post. Thanks in advance, Pete Buckeye
RE: Fuel Filter and EGR Valve Replacement - 5/4/2005 12:30:44 PM
Evlampius
Welcome! Fuel filter is a job that requires a lot of dexterity and patience. First you need a special tool - like a special wrench head , it's the only way to access the back nut - and you can only get to it from the bottom ( I didn't try to do it from the top though ). 94-97 fuel filters are a mess, be prepared to be covered with gasoline In other words - it is doable but ain't worth your time and nerves if you dont have the tool nor the lift to lift up the car. I say pay the garage for replacement if labor is withing $50 it's ok. about EGR Valve - why do you need it replaced? what is the problem?
RE: Fuel Filter and EGR Valve Replacement - 5/4/2005 5:22:08 PM
Buckeye
Thanks for your help, As far as the EGR valve, I thought it was part of the regular maintenance service. I contacted the dealer (about the fuel filter issue), and they stated it is not a regular maintenance item, and only changed when it acts up. Regarding the fuel filter, it is about $70 to get it changed at the dealer (so probably worth the $$ given the mess it seems to cause). However, the same dealer also stated it was a lifetime filter, so should not require changing. I did speak with them about changing the brake fluid, which was $40. However, they stated they only changed the fluid in the master cylinder. This seems like a lot for sucking a few cups of brake fluid out and pouring in some more. Regards, Pete Buckeye
RE: Fuel Filter and EGR Valve Replacement - 5/4/2005 9:28:09 PM
Evlampius
Dude, lets not get all crazy about it? As long as everything works, no Engine light with EGR failure code, dont touch it ok? dealer charges $70 bucks - well i believe that there are other garage shops around that will do the job for less and do that right. However if it doesn't hurt you extra $20 , go with that. yes there are lifetime fuel filters - the problem is - filters do not live that long :) ...when you replace the filter you can ask to get the old filter back - now , just turn it upside down and try to tap it on your hand - you'll be amased how much sand you will get on your palm. brake fluid i dont know - , basically if you bleed your brakes once in a while the fluid circulates - just make sure you add the fluid that is specified in the manual. I understand your passion for jumping on the car and start replacing stuff, start with something easy, how about spark plugs and air filter - replacing distributor cap and rotor? that stuff you can do yourself and feel good about it
RE: Fuel Filter and EGR Valve Replacement - 5/4/2005 10:50:14 PM
Evlampius
I just thought of something - may be it was a PCV valve you wanted to replace?? you can do that - it costs around 7-10$ and can be replaced easily. theres actually a way to test your pcv valve (positive crankshaft ventilation valve) that is on the valve cover. I was surprised that it improved my mileage from 22 to 24 miles per gallons. I change it every 6-9 months. anyway - if you want i can guide you how to test your pcv valve.
RE: Fuel Filter and EGR Valve Replacement - 5/5/2005 12:06:25 AM
Evlampius
you, master mechanic you!!
RE: Fuel Filter and EGR Valve Replacement - 5/5/2005 12:25:23 AM
Joined: 8/30/2004 From: Canton/Massillon, Ohio 44646 Status: offline
Yes this job is not the easiest one to accomplish for the first time, you can more than likely find one of your towns back yard wrenchs to do it for about $ 25.00 to 40.00. WheelBrokerAng quote:
ORIGINAL: Evlampius Welcome! Fuel filter is a job that requires a lot of dexterity and patience. First you need a special tool - like a special wrench head , it's the only way to access the back nut - and you can only get to it from the bottom ( I didn't try to do it from the top though ). 94-97 fuel filters are a mess, be prepared to be covered with gasoline In other words - it is doable but ain't worth your time and nerves if you dont have the tool nor the lift to lift up the car. I say pay the garage for replacement if labor is withing $50 it's ok. about EGR Valve - why do you need it replaced? what is the problem?
_____________________________
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
RE: Fuel Filter and EGR Valve Replacement - 5/5/2005 12:27:23 AM
Hey BuckEye Pete, just where in Ohio do you live...? Or are you from Ohio and livin somewheres else? WheelBrokerAng.. Ohio
RE: Fuel Filter and EGR Valve Replacement - 5/7/2005 6:11:44 PM
Buckeye
Evlampius, Thanks for the info. I have been doing much of the maintenance myself for the last few years (oil changes, plugs and wires, brakes, etc.). I did stop by the dealer to pick up some filters and a PCV valve today. The valve was $19 (ouch), but the desk person at the dealer asked why I wanted to replace it. I mentioned normal manitenance, and she stated that if you pulled it off and it rattled, it was functioning and did not need replacement. I went out in the lot and did this; sure enough it sounded like a BB shaking around in there, so I did not ended up getting the replacement. Was this "shake test" the one you were referring to to check the valve ? Would you still recommend replacing it every 6-9 months ? If so, do you spend $19 for the Honda version, or a cheaper off-brand ? WhelBrokerAng, I am still in Ohio (Columbus), but I grew up in Northern Ohio (Broadview Heights). My folks told me they had like a foot of snow a couple weeks ago . Hope things have warmed up there. Buckeye
RE: Fuel Filter and EGR Valve Replacement - 5/7/2005 7:33:40 PM
Evlampius
see, did I tell you to shake it?? I said - and I QUOTE : "if you want i can guide you how to test your pcv valve." do you really think that I would just tell you to shake it ?? and yes even those that are bad are rattling. So now I'm gonna tell you how to check it , but before that I'm gonna slap you!!!
RE: Fuel Filter and EGR Valve Replacement - 5/7/2005 8:05:06 PM
Evlampius
OK - so The vacuum hose that is attached to PCV valve is holding the valve open by vacuum... take it out and shake it..... LOL ! just kidding... take a pair of wide nose pliers - take a rag , cover the vacuum hose in the middle and gently squeeze the hose ( and I mean gently, do not damage the hose!) till the point where the hose is completely closed - you will hear (or will not) "click" from the PCV valve - release the pliers and you will hear another "click" . Try it couple of times hear the "clicks" if you DO hear them PCV valve is OK. Although Honda Original PCV valve is better quality , spending $19 bucks for it - is a little too much. I'm buying the PCV valve at local PepBoys store for $3 dollars (because it's my business price) regular customer price is bellow $10 bucks <-- those cheap a$$ valves will fail more frequently than Honda OEM, thus the replacement every 6-9 months. Here is a very good site I found with Honda Parts - I have found this site be very user friendly and the shipping is very fast! try it see as you might find a good deal there - this month deal is $100 bucks timing belt/pump/drivebelts package deal. visit here : T.A.S. Autoparts I wish you all the best and contact me if you have any other questions. Evlampius. P.S. I hope you're not offended by my posts , sorry if you find my posts offensive or somthing...I try adding some smilies so it wouldn't look that harsh and I hope you dont take me seriously while me being a$$ , making fun of people! OK??
Vroom...vrooom....vrooooooooom!!!
RE: Fuel Filter and EGR Valve Replacement - 5/7/2005 10:41:50 PM
Buckeye
Thanks for the great info; I'll try it tomorrow. Don't sweat the being "offensive" part, I'm pretty easy-going. Regards, Pete Buckeye
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
