Fuel Tank Vapor Control Valve?
  Printable Version
Honda Accord Forum >> General >> Do-It-Yourself Section >> DIY Requests >> Fuel Tank Vapor Control Valve? Page: [1]
Login
Fuel Tank Vapor Control Valve? - 10/22/2008 9:33:02 AM
480Ruger
Score: 0
Status: offline
The MIL came on after I filled the car up two nights ago.  No codes and the scan tool says the light should be off.  I have the 98-02 Service Manual V6 Supplement but not the Service Manual.
How do I check the Fuel Tank Vapor Control Valve?  Any other things that cause this problem while/from fueling?
Thanks Gregg
_____________________________
Ground Pounder Gregg
99 Accord EX V6 AT 4D
00 Dodge Diesel 702 HP Race Truck
03 H-D Fatboy
Post #: 1
RE: Fuel Tank Vapor Control Valve? - 10/22/2008 9:35:16 AM
finch13
Score: 0
Status: offline
Not screwing on the gas cap at least 3 clicks will trigger the CEL and tell you to check the evap can and what not.
If the light is still on scan it again and clear the code... or try a different tool.
USE ME TO SEARCH HAF
PWOTY 2008!
(in reply to 480Ruger)
Post #: 2
RE: Fuel Tank Vapor Control Valve? - 10/22/2008 11:43:40 AM
480Ruger
Score: 0
Status: offline
I did not know that would cause a code but I actually tried that just to see and even disconnected the battery for thirty minutes just to see if it would clear the light. Still no codes to clear and I did use a friend’s scan tool along with mine.  I’m not sure if I’m even on the right track.  I just know what I was doing when it started which was just filling up.
If I did want to check the Valve what do I need to do and is it on top of the tank where the fuel pump housing is?
03 H-D Fatboy
(in reply to finch13)
Post #: 3
RE: Fuel Tank Vapor Control Valve? - 10/22/2008 11:53:52 AM
finch13
Score: 0
Status: offline
001 FILTER SET, FUEL
003 PUMP SET, FUEL
005 VALVE, ONE-WAY
007 FILTER SET, FUEL PUMP
011 VALVE, VENT SHUT (O.R.V.R.)
016 METER ASSY., FUEL
028 TUBE, VENT
< Message edited by finch13 -- 10/22/2008 11:57:17 AM >
PWOTY 2008!
Post #: 4
Page:   [1]
Honda Accord >> General >> Do-It-Yourself Section >> DIY Requests
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
