Fuel filter location on a 97 Accord
  Printable Version
Honda Accord >> General >> General Tech Help >> Fuel filter location on a 97 Accord Page: [1]
Login
Fuel filter location on a 97 Accord - 9/16/2005 9:39:46 AM
mojorison_75
Status: offline
Where is the fuel filter located on a 1997 Accord SE? Is it in or outside the tank?
Post #: 1
RE: Fuel filter location on a 97 Accord - 12/4/2005 12:00:04 PM
overlordjd
Status: offline
The filter is on the drivers side of the car close to the fire wall. Just follow the hose that goes down from the fuel rail.
(in reply to mojorison_75)
Post #: 2
RE: Fuel filter location on a 97 Accord - 12/4/2005 4:40:39 PM
deserthonda
Status: offline
under the brake master cylinder ...like ovr said follow the top line /// the trick is to get a 14mm crow foot, a long extension and a rachet ..raise car, loosen the bottom line. lower car, remove the 17mm banjo bolt at the top, undo the lower line from the top u might want to put a pan under filter some fuild will spill. remove the 10mm bolt that attaches the fuel filter bracket and remove the filter/bracket assembly ..it is a bit of a tight fit but it will come out ,, once out remove the 10mm bolt and replace the filter ...............once u go back in,, firtst thing u do is start the bottom line from the top finger loose then put top all together and last thing do not forget to tighten bottom line
(in reply to overlordjd)
Post #: 3
Page:   [1]
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
