G23 info
  Printable Version
Honda Accord Forum >> Your Ride >> Engine & Internal >> G23 info Page: [1]
Login
G23 info - 10/31/2007 9:30:13 AM
00AccordLX5spd
Status: offline
Anyone with questions about the infamous G23 "frankenstein" engine, click here: http://www.honda-tech.com/zerothread?id=1046336&page=1
_____________________________
2000 Accord LX Sedan F23A1 5spd
-Short Shift Adapter
-eBay SRI w/ K&N
1995 Accord V6 Sedan AT - AKA "the money pit"
1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
Post #: 1
RE: G23 info - 10/31/2007 1:34:11 PM
marbro
Status: offline
and keep in mind that it changed,  it went from a h23 head to a f22b dohc head which is much rarer, and the dyno is based on a prelude that i believe was gutted to weigh 2400lb's
98' Accord project car/ Daily driver
(in reply to 00AccordLX5spd)
Post #: 2
RE: G23 info - 10/31/2007 1:38:12 PM
falkore24
Status: offline
falkore24's photo gallery
quote:
ORIGINAL: marbro
... the dyno is based on a prelude that i believe was gutted to weigh 2400lb's
huh???   weight doesn't factor into the dyno.   Definately acceleration, braking, and handling, but not the dyno #'s
(in reply to marbro)
Post #: 3
RE: G23 info - 10/31/2007 1:38:48 PM
00AccordLX5spd
Status: offline
Yeah I knew the dyno was based on a lude, but lots of build info is there.  One of the mods on 6thgenaccord.com has a G23 in his 6th gen.  He dynoed it at around 155whp.
-eBay SRI w/ K&N
Post #: 4
RE: G23 info - 10/31/2007 1:41:42 PM
falkore24
Status: offline
daNG ..... pretty crappy peak HP ....... that doesn't tell the tale of the curve though!!!
< Message edited by falkore24 -- 10/31/2007 1:43:36 PM >
Post #: 5
RE: G23 info - 10/31/2007 4:38:58 PM
marbro
Status: offline
still involves a crap load of dyno work and redoing the fuel map....            i would assume that they werent running a 6th ecu either?     and im sure they didnt increase the compression or bore out the sleeves
(in reply to falkore24)
Post #: 6
RE: G23 info - 12/4/2007 11:13:18 AM
KevinAccord
Status: offline
that doesn't sound like such a good idea now... just 5 more HP? wtf?
2000 Accord LX i4 Turbo AT
18" Konig Unknown Rims
MSD 6AL
Gold Line Suspension
Apexi Neo
Few other Mods...
Mini Cooper 2006 MT
HID's
17" Rims
Premium Package
Sport Suspension
Short Shifter
Panoramic Sunroof
Stock Engine (For
Post #: 7
RE: G23 info - 12/4/2007 11:21:17 AM
falkore24
Status: offline
Kevin ...... did you know that you can't really tell anything about an engine's performance by it's peak HP?  HP is calculated, torque is real.  What matters is how much torque you are making per rpm before the peak.  The peak matters when you are on the track, but that's about it.  The torque delivered by this build from 2000-5000 rpm's is what makes it a very good idea.  This is what you use for a daily driver!
HP = (rpm*ft.lbs.)/5252
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to KevinAccord)
Post #: 8
RE: G23 info - 12/4/2007 11:29:58 AM
KevinAccord
Status: offline
WOW! thank you! i didn't knew that actually... Falkore, ur the man! i knew torque was inportant as well as HP, but not that it was that important! so u think it's a good idea for me to get the H22 head? or is it the H23?
MSD 6AL
Apexi Neo
Few other Mods...
Mini Cooper 2006 MT
HID's
17" Rims
Premium Package
Sport Suspension
Short Shifter
Panoramic Sunroof
Stock Engine (For
Post #: 9
RE: G23 info - 12/4/2007 11:37:50 AM
00AccordLX5spd
Status: offline
quote:
ORIGINAL: KevinAccord
That's wheel horsepower.  The stock 6th gen f23a1 accord has 150 at the crank, not the wheels.  A stock auto accord probably only puts like 120hp(that's being generous) to the wheels. A little more for the manual transmission, but still nowhere near 150 to the wheels.
< Message edited by 00AccordLX5spd -- 12/4/2007 11:38:33 AM >
-eBay SRI w/ K&N
Post #: 10
RE: G23 info - 12/4/2007 11:38:11 AM
falkore24
Status: offline
It depends on the amount of boost that you want to push ..... I posted on another thread what compression ratio results from both heads ..... are you trying to have the turbo and VTEC or do you plan to eliminate the VTEC ..... one has it and the other doesn't .... too lazy to look up the Wiki right now.
Before you do anything though, I'd try to find actual dyno maps to compare so that you can predict the actual benefit.
2000 V6-AT (RIP 3G)
Post #: 11
RE: G23 info - 12/4/2007 11:40:25 AM
00AccordLX5spd
Status: offline
Of course the results will vary.  This is a "frankenstein" motor.  there's no telling what kind of gains any particular build will get you cause I nothing can be exactly the same when your swapping around parts from used engines.
-eBay SRI w/ K&N
Post #: 12
RE: G23 info - 12/4/2007 11:46:26 AM
KevinAccord
Status: offline
yeah i guess... i'll make sure i have enough info before i get into something serious... thanx guys... and Jon, thanx... didn't knew the exact #'s, i thought hey were talking to the crank as well...
MSD 6AL
Apexi Neo
Few other Mods...
Mini Cooper 2006 MT
HID's
17" Rims
Premium Package
Sport Suspension
Short Shifter
Panoramic Sunroof
Stock Engine (For
Post #: 13
Page:   [1]
Honda Accord >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
