Genuine Brake Fluid?
Login | |
Genuine Brake Fluid? - 10/10/2007 10:57:01 AM
bbdhong
Hi, Experts, I am about for my mechanic to change my brake fluid for my Accord 2000 and Odyssey 2001. Can I use generic Brake Fluid or do I need to stick on the Honda Genuine Brake Fluid? Is there a big difference? Thanks for your help in advance.
< Message edited by bbdhong -- 10/10/2007 10:58:54 AM >
_____________________________
2000 Honda Accord LX 4spd Automatic 2001 Honda Odyssey EX 4spd Automatic 2002 Acura RL 3.5 4spd Automatic
RE: Genuine Brake Fluid? - 10/10/2007 11:08:05 AM
00AccordLX5spd
Generic Dot 3 or Dot 4 is fine. I put Dot 3(I think it was prestone brand - they had a buy 1 get 1 free deal at the auto parts store) in my 95 when I changed the brake master cylinder a few months ago.
2000 Accord LX Sedan F23A1 5spd -Short Shift Adapter -eBay SRI w/ K&N 1995 Accord V6 Sedan AT - AKA "the money pit" 1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
RE: Genuine Brake Fluid? - 10/11/2007 12:11:36 AM
bbdhong
I am going to try to change the brake fluid this weekend. How much brake fluid do I need to prepare before I start to change? I cannot find the spec. Also, I am not quite sure since I am a newbie for mechanic. After you suck the fluid from reservoir, then loosen the brake bleed screw. Do I need to loose little bit or completely take off the bleed screw? If I take off the bleed screw, Is the brake fluid going to flow out like when you drain the transmission fluid? I am little bit afraid to make messy when I do this job. I read DIY section for this but cannot understand completely this. Thanks a lot.
RE: Genuine Brake Fluid? - 10/11/2007 12:16:31 AM
2POINTautO
I have not seen any articles talking about genuine brake fluid similar to using a very specific antifreeze designed for your engine. Just make sure its the correct rating, DOT 3 or DOT 4 or DOT 5. DO NOT use silicone fluid in non silicone fluid required systems is the only warning I have noticed. DOT 3 to DOT 4 only raises the boiling point temperature.
Give all the dirty details Year, Make & Model help too Here to help if I can
RE: Genuine Brake Fluid? - 10/11/2007 5:39:55 AM
JimBlake
DO NOT USE DOT5. That IS silicone fluid. DOT 5.1 is OK, but those fluids are generally labeled as DOT4 because they satisfy those requirements too. Probably 1 liter for each car. If you buy extra don't break the seal. The 2-year lifespan for fluid begins when you break the seal, regardless whether it's in the car or in the bottle. 1 - Get a helper to push the pedal as you work the bleed valve. 2 - Suck out the reservoir fluid & refill with fresh. 3 - Start with the left-front. Get a hose that fits over the end of the bleed screw, drop it into a jar to catch the fluid. 4 - Helper pumps the brake pedal a couple times & then holds it down. 5 - You open the bleed valve just enough for fluid to come out. 6 - Try to close the valve before his pedal gets all the way to the floor. 7 - Repeat 4-5-6 maybe 10 or 15 times. Refill the reservoir. With some experience you'll know how many you can do before refilling. 8 - After about 200ml or 250ml go to the next wheel in order. By that time you should not have any air bubbles coming out. If you DO, then you'll want to send someone for extra fluid... DO NOT LET THE RESERVOIR GET EMPTY. If it does & sucks air, you basically have to start over. Bleeding order for your Accord is LF - RF - RR - LR. I guess the Odyssey would be the same but I'm not real sure. This bleeds the ABS; you do not have to do anything special.
< Message edited by JimBlake -- 10/11/2007 5:44:04 AM >
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
RE: Genuine Brake Fluid? - 10/11/2007 5:45:34 AM
2POINTautO
With inexperienced help, I have them put a shoe behind the brake pedal so that it cannot go all the way to the floor, it only needs to go half way, going more than normal travel is taking a chance on damaging the internal seals.
RE: Genuine Brake Fluid? - 10/11/2007 6:23:44 AM
00AccordLX5spd
Jimblake nailed it. I bled my brakes for the first time when I changed out my master cylinder. It was super easy (besides having to remove all the wheels one at a time cause I couldn't reach the bleed screw with the wheel on.) The bleed screw will have a little rubber nipple cover on it. You may want to use a closed end wrench or a flare nut wrench (mine was 10mm) to break the bleed screw loose the first time as it could be pretty hard to brake loose due to moisture buildup, etc.., and it would suck if you rounded it off. You should only have to turn it about 1/2 turn and brake fluid will come out. It kind of squirts out in bursts as the brake pedal is mashed down.
< Message edited by 00AccordLX5spd -- 10/11/2007 6:26:19 AM >
RE: Genuine Brake Fluid? - 10/11/2007 11:11:30 AM
bbdhong
Wow. Great!!.. And quick responses. Thanks for all your great info. It makes me much more comfortable to do this maintenance job. For 2000 Accord, do I need to take off wheel to loose bleed screw? When I see the diagram, it looks like little bit challenge to access rear bleed screw without taking off the wheel. Though I didn't try it yet. During past few weeks, I changed my spark plugs, transmission fluid, coolant after I get the info. from this site and save lots of $$$. My local dealer asked $125 for spark plug changes - I spent only $40 for Denzo Iridium spark plugs (IK16). I can feel the difference. $70 for tranmission fluid drain and fill - Spent $20 for Honda ATF-Z1 for one drain and fill. I did twice and the color of fluid looks clean red. Shift seems to be great. Even if I was fooled from my local dealer for parts. They charged $2.40 for little transmission drain plug washer. I thought that was regular price and felt too expensive, but I bought. few days later, when I stop by Acura dealer and asked the price of same part, they said $0.30!!! Yikess, I will go to Acura dealer next time. $70 for coolant change - Spent $13 for genuine Honda coolant. Kind of expensive as well but believe it will be worth investment like you guys said $45 for engine air filter - Spent $13 for generic part. $60 for cabin air filter - Spent $10 for generic part. $65 for brake fluid change. - Not done yet. With these maintenance jobs, I feel my car runs like brand new and good gas mileage now. About 27 mpg (city 45%, highway 55%). Much better than before, I usually got 23 mpg.
< Message edited by bbdhong -- 10/11/2007 11:20:51 AM >
RE: Genuine Brake Fluid? - 10/11/2007 11:16:01 AM
00AccordLX5spd
If I were you, I would take off the first wheel you do so you can get oriented with where the bleed screw is. If you have drums on the rear though, the bleed screw will be in a different location than on the discs. Even after doing this, it was easier for me to remove the wheel than to try to fenagle a wrench in there to get to the bleed screw. Although many say it is not necessary to remove the wheel. I guess if you raise the car up you can access it from the inside, but I still think remioving the wheel is easier. It's only 4 lug nuts anyway!
RE: Genuine Brake Fluid? - 10/11/2007 11:16:23 AM
falkore24
Does that $65 brake fluid change include bleeding the old fluid out of the lines or do they just suck out the reservoir and refill?? If they do it right, I'd probably let them do it for $65.
RE: Genuine Brake Fluid? - 10/11/2007 11:18:50 AM
00AccordLX5spd
quote:
ORIGINAL: falkore24 Does that $65 brake fluid change include bleeding the old fluid out of the lines or do they just suck out the reservoir and refill?? If they do it right, I'd probably let them do it for $65. Are you crazy? You won't even have to use but maybe $10 or $15 worth of brake fluid!
< Message edited by 00AccordLX5spd -- 10/11/2007 11:20:15 AM >
RE: Genuine Brake Fluid? - 10/11/2007 11:24:57 AM
drummer1279
Joined: 8/4/2006 From: greenville, south carolina Status: offline
DOT3-4 brake fluid is not silicone...the DOT 5 and all specifically named ones are silicone.
Do not taunt happy fun ball... 1992 Accord LX Automatic
RE: Genuine Brake Fluid? - 10/11/2007 11:28:41 AM
JimBlake
quote:
ORIGINAL: 00AccordLX5spd Are you crazy? You won't even have to use but maybe $10 or $15 worth of brake fluid! Yeah, but some people don't like the whole crawl-underneath & get dirty scene. If you have 15" wheels there's probably not enough room to get at the bleeder screws. If you have 17" there's probably lots of space. Either way, make sure the car is supported properly so it doesn't fall on you.
RE: Genuine Brake Fluid? - 10/11/2007 11:30:00 AM
falkore24
YES 00, very much so!!! It's more the time issue than the money for fluid. Jim, I actually like to get dirty ..... hands on ftw!!! Just that I have very little free time.
< Message edited by falkore24 -- 10/11/2007 11:32:18 AM >
RE: Genuine Brake Fluid? - 10/11/2007 11:31:09 AM
bbdhong
Oh... Good point. I didn't ask whether they will bleed the brake fluid or just remove the old fluid from reservoir and fill. Acura dealer said Brake fluid change for my RL would be $120 though. I might need to ask them for detail. Ya.... maybe, I better let dealer do it at that price since I need to jack up front and rear, and do all 4 wheels. Also, it's first time and I may have some trouble. But once I get some experience, it looks like easy job though. By the way, Sears Auto Service quoted $35 for change the brake fluid but didn't ask whether they bleed the brake fluid from all 4 wheels. Does some auto shop change the brake fluid without bleeding? Just remove and fill the fluid in reservoir. I think I can do it within few minutes if they do like that. If they do this way, Are there problems?? Sorry for too many questions and speaking. Fogive me since I am newbie like I said. Lots of questions and unclear things even after reading DIY and service manual.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
