HELP! Noise from exhaust system
  Printable Version
Honda Accord Forum >> Your Ride >> Headers, Intake, & Exhaust >> HELP! Noise from exhaust system Page: [1] 2   next >   >>
Login
HELP! Noise from exhaust system - 12/3/2007 3:13:36 AM
jinstyle
Status: offline
My car has recently been driving me nuts.  I have a rattling noise problem.  One that seems to be coming from the area right under the left rear seat.  Sounds like my cat back is bouncing on the frame or the bumper or something like it. When I checked under the car while it was still making the noise I found nothing...  Another is when I give the car a little throttle I hear a whining belt slipping noise.  I'm guessing both problems could be my OBX header since that was the last mod I did on the car and never heard a sound until I switched from the stock header.
I guess my question is does anybody with the OBX header for the 4cyl have any similar problems?  I might just switch back to my stock header if I can't figure this out.  I feel like I'm ruining Honda’s reputation by driving around in the fabulous accord and making crappy rust bucket noises.  Any thoughts will be greatly appreciated.
_____________________________
2004 Accord Coupe EX-L 2.4L 5AT
AEM SRI / OBX R Exhaust Header / Greddy SP2 Exhaust
Acura TL 17mm Anti Sway Bar /
Post #: 1
RE: HELP! Noise from exhaust system - 12/3/2007 6:46:06 AM
falkore24
Status: offline
falkore24's photo gallery
The cat is near the engine.  The location that you describe is where the resonator is.  If I werre you, I'd check the cat-back system to make sure that all hangers are ok and that nothing is hitting metal-to-metal.  I have the V6 with an OBX header and in 4 years have never had any problems with it.  I've heard that their gaskets aren't the greatest, but since I haven't added nitrous yet, I haven't burned it out.
For the belt noise, have you actually checked the belts?  It might just be coincidental ...... actually it's most likely that it is since an exhaust leak doesn't sound anything like a belt slipping.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to jinstyle)
Post #: 2
RE: HELP! Noise from exhaust system - 12/3/2007 1:36:28 PM
jinstyle
Status: offline
actually now that I think about it haven't checked the belts.. i will definitely go check it. As for the resonator you are dead on I couldn't tell before because i was in park but as soon as I put it in drive and pulled the e-brake to keep it from rolling the resonator was hitting the frame. I guess it just needs to be bent a few degrees so that it lines up in the center.
Thanks for the advice =)
(in reply to falkore24)
Post #: 3
RE: HELP! Noise from exhaust system - 12/5/2007 9:39:10 AM
19Accord97
Status: offline
19Accord97's photo gallery
My WS2 was hitting a nut barely right after the resonator, so when it was under a load or I suddenly let off it started going  BBBBBBMMMMMMMMMMMZZZZZZZZZZZZZ and you could feel it like crazy!  So I just coveered the nut in high temp silicone and havent had a problem since unless it rains, then it still does it.
As for the OBX header, I had one for about a yeah and a half and just took it off a few months ago.  The gaskets kept blowing out and my mpg kept dropping and it is a pain in the butt.  So the stock manifold is back on:(.
Scopin out my old turf......
Post #: 4
RE: HELP! Noise from exhaust system - 12/5/2007 9:50:28 AM
falkore24
Status: offline
There is a fairly common exhaust problem that I fealt is worth mentioning here, even though it is not your problem.  The factory mid-pipe has a small tube inside the one that you can see.  If the inner tube breaks, it will rattle against the outter one.
2000 V6-AT (RIP 3G)
(in reply to 19Accord97)
Post #: 5
RE: HELP! Noise from exhaust system - 12/5/2007 3:36:26 PM
jinstyle
Status: offline
What a coincidence~! I just did the same thing last night. I couldn't think of any other solution so I put silicon on it and so far so good. It's snowing in michigan so the roads are really wet and luckily haven't heard any rattling yet so.. hope it stays good. As for the OBX I'm in a bind because It's doing well so far but if in the future the gaskets keep on blowing like you mentioned I don't know what to do.. Since I replaced the old stock header due to extreme rust. Options at this point are the DC version or stock which are almost equally expensive. =(
Post #: 6
RE: HELP! Noise from exhaust system - 12/5/2007 3:45:30 PM
chopperkid44
Status: offline
chopperkid44's photo gallery
lol. ive had this problem but it kinda went away on its own or at least its gotten better.
My victims in races: 96 slightly modded civic, 02 Audi A4 1.8T, Pontiac Grand Am coupe
'94 EX Coupe
76K miles
f22b1 5spd
BOMZ Cold air intake
Megan Racing Full exhaust and header
16" Konigs
Smoked Euro Tailights
Post #: 7
RE: HELP! Noise from exhaust system - 12/5/2007 9:13:02 PM
19Accord97
Status: offline
quote:
ORIGINAL: jinstyle
That is funny!
B/C I put silicone on where it was hitting
Ive lived in Michigan (Benton Harbor)
And I am thinking about POSSIBLY replacing it with DC sport ones! haha
Post #: 8
RE: HELP! Noise from exhaust system - 12/5/2007 9:45:03 PM
94Honda
Status: offline
quote:
ORIGINAL: jinstyle
did u double up your header gasket? like on my firebird and camaro i had to double them up and never had a prob. all my friends with cars w/headers did that and dont have any probs. either
94'' Accord LX, AT,
Cold Air
Silverline EX.
All Synthetics
NGK Iridium''s
RF 12" P3, P6001bd
1/0 Ga. Power, 1/0 Ground,
10 Farad Digital Hybrid Cap.
T162S RF Components, And
A Double Layer of 80m Dynamat.
Post #: 9
RE: HELP! Noise from exhaust system - 12/6/2007 10:04:33 AM
falkore24
Status: offline
.... or just get a better gasket from an auto parts store
2000 V6-AT (RIP 3G)
(in reply to 94Honda)
Post #: 10
RE: HELP! Noise from exhaust system - 12/6/2007 11:03:50 AM
94Honda
Status: offline
or that.
94'' Accord LX, AT,
Cold Air
Silverline EX.
All Synthetics
NGK Iridium''s
RF 12" P3, P6001bd
Post #: 11
RE: HELP! Noise from exhaust system - 12/6/2007 2:06:03 PM
chopperkid44
Status: offline
good idea. but im not having a problem so i dont need one now. lol
'94 EX Coupe
76K miles
f22b1 5spd
16" Konigs
Post #: 12
RE: HELP! Noise from exhaust system - 12/6/2007 4:46:24 PM
jinstyle
Status: offline
quote:
ORIGINAL: 94Honda
quote:
ORIGINAL: jinstyle
I know this seems like a stupid question but by double up you mean use two gaskets instead of one?
Post #: 13
RE: HELP! Noise from exhaust system - 12/6/2007 8:06:19 PM
94Honda
Status: offline
yeah, its just that much more gasket for a betterseal
94'' Accord LX, AT,
Cold Air
Silverline EX.
All Synthetics
NGK Iridium''s
RF 12" P3, P6001bd
Post #: 14
RE: HELP! Noise from exhaust system - 12/6/2007 8:45:17 PM
jinstyle
Status: offline
Hey 19Accord97 I remeber a while back when you posted "OBX header Facts" you used a lot of silicon with your gaskets.  What would you recommend: add silicon to gaskets or just go buy a better gasket? or both go buy better gaskets and add silicon?
Post #: 15
Honda Accord >> Your Ride >> Headers, Intake, & Exhaust
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
