HID problem
Login | |
RE: HID problem - 11/21/2008 12:38:19 PM
finch13
How are you HIDs wired? Are they Headlight Plug -> Ballast -> Bulb Or Battery -> Relay -> Ballast -> Bulb? 20A fuses are more than plenty, I have 5A inline fuses for mine and my ballasts are rated for like 7A or something and they don''t burn out... you may be frying the ballasts somehow.
_____________________________
USE ME TO SEARCH HAF PWOTY 2008!
RE: HID problem - 11/21/2008 1:15:13 PM
cjdm98
Its headlight>balast>bulb.. But the thing is now i notice that when i flick the light to come on it clicks,and i cam here it coming from the fuse box under the hood.
>>Click here to see my Accord<<
RE: HID problem - 11/21/2008 1:18:59 PM
finch13
You relay contacts are probably worn out... that''s what''s clicking the fuse box.
RE: HID problem - 11/21/2008 1:22:46 PM
cjdm98
I read that the HID and or ballast arent getting the right amout of power to operate properly..and i need to install a relay harness kit?
RE: HID problem - 11/21/2008 1:28:29 PM
finch13
Possibly... you can make you''re own, I did. Basically, with the kit, the ballasts draw their power directly from the battery and not through the switch on the steering column.
