HOLY COW-
Login | |
HOLY COW- - 10/16/2007 3:05:09 PM
mymunkee1
Score: 0 Joined: 10/16/2007 Status: offline
WELL- I HAVE AN 88 ACCORD LXI THAT THE WATER PUMP WENT OUT IN...UNFORTUNATELY, THE YUTZ THAT TRIED TO REPLACE IT SAYS HE "ROUNDED OFF" A BOLT THAT HOLDS THE CASING TO THE HEAD? OR WHEREVER- HOW DO I PUT THE NEW ONE IN NOW?? THANKS
RE: HOLY COW- - 10/16/2007 3:49:48 PM
sir_nasty
Score: 0 Joined: 2/23/2006 Status: offline
What bolt did he screw up? did he just hash the threads on it or what?
_____________________________
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''''s great but it''''s not all beer and skittles
RE: HOLY COW- - 10/16/2007 5:50:12 PM
RTexasF
Forum Monitor Posts: 2357
Score: 0 Joined: 11/16/2004 From: Brownsville, TX Status: offline
There are screw and bolt extractors for both rough edged and broken off bolts & screws. One such product is called an easy out. If you have some basic tools you may be able to remove the offending bolt/screw yourself. If not ask a mechanically inclined friend. Good luck Mom, we're rooting for you. That's just the removal then tapping new threads into the old hole may be required for a new bolt.
< Message edited by RTexasF -- 10/16/2007 5:53:05 PM >
''''04 2.4l 5M EX Sedan Neuspeed short shift kit V-6 6 speed front strut/firewall brace 17mm rear anti sway bar AEM Shorty DC Sports SS Header Kicker Speakers JL Audio Clean Sweep JL Audio Amp 200W Bazooka sub V-6 OEM 7 spoke alloys
RE: HOLY COW- - 10/17/2007 12:43:11 PM
falkore24
Score: 0 Joined: 8/16/2007 From: Wayne, NJ Status: offline
A tap cuts threads in a hole ..... when threadlock is used, a tap can clean/recut the threads. The compliment is a die that cuts the threads on the bolt. The tap is basically a bolt with a sharp cut down the length of the threads, usually made of hardened steel so it is stronger than the metal being threaded.
RE: HOLY COW- - 10/17/2007 9:26:56 PM
deserthonda
Score: 0 Joined: 12/3/2005 Status: offline
if it is one of the 4, 6mm bolts ( 10mm head ) that holds the water pump to the block,, it is not such an easy job to drill it out , there is not very much room,, one would need an angle drill, remove the mount and raise the engine patialy up to get more room , then hopefully it can be removed using an easy out , if not, it all needs to be drilled out and might have to use a ( heli-coil ) in the threads to make it back to a 6 mm .. so one can use the 6 mm bolts again.. I am not sure that this is such a task that you might want to try it yourself,, Now ,if there still is some threads sticking out of the block , then it might be removed without having to drill anything .. The idea of taking a picture and posting it here was a great suggestion , hope that you can do so,, It would clarify a lot of things for us
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: HOLY COW- - 10/19/2007 10:09:18 PM
nafango2
Score: 0 Joined: 8/18/2007 Status: offline
from what i understood he stripped the head of one of the bolts on the valve cover, but im not really sure. if you have a drill you can buy an extractor set from sears for about $7. It should come with some instructions. You can find out whether a bolt is stripped (or 'rounded off') if it has a flat top (no + or - indentation where a screwdriver goes) and goes in what looks like a circle with a slight hexagon look to it. The "sides" of the bolt head (the part at the top) would have some shiny-ness in striped pattern around the sides. or, when the engine is cold look at the large horizontal box in the center of the engine. There are black bolts all around it, that have a hexagon-shaped top. look for the one that doesnt look too hexagon-ish. That will be the on you have to remove.
96 Accord LX 4cyl. 4dr AT w/o vtec (F22B2) Security System / Keyless entry
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
