HOW TO,,,,CLEAR SRS LITE
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> HOW TO,,,,CLEAR SRS LITE Page: [1]
Login
HOW TO,,,,CLEAR SRS LITE - 5/18/2006 3:24:54 AM
deserthonda
Score: 0
Status: offline
(should work for all honda)
On every single accord i have worked it has been located under the dash, left side ,, it is a yellow ( SRS connectors are all yellow ) 2 wire connector,either ( gray..gray ) or( green ,, green ) on occasion it is a pain to locate it ,, but it is there ..
*tools- paperclip, flashlight , SCS connector ( if possible ) ,,most of you do not have the scs connector so just use paper clip
Once you find it,, jump the wires together, use SCS connector or , Insert paperclip ...
WHEN YOU DO THIS YOU HAVE TO BE FAST ON CONNECTING AND DISCONNECTING , whatever you use to jump the wires,,, if you have the SCS service connector it would make the job a lot easier..
Erasing the DTC memory/resetting SRS light
1) turn ignition switch off
2) jump the SRS ( MES) connector ( MES = Memory Erase Signal ,) using the scs connector or paper clip
3) turn ignition switch to on
4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector ( paperclip) from the MES connector within 4 seconds after the SRS indicator light went off
5) The SRS indicator will come on again. Reconnect the SCS service connector ( paperclip,) to the MES connector : within 4 seconds after the light comes on.
6) When the SRS indicator light goes off, remove the SCS service connector ( paperclip ) from the MES connector within 4 seconds.
7) The SRS indicator light will blink 2 times indicating that the memory has been errased/clear.
8) turn the ignition switch to off and wait for 10 seconds.
it should be cleared.........If not repeat the procedure.......
Hope this helps some of you...
< Message edited by deserthonda -- 5/18/2006 3:28:54 AM >
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
Post #: 1
Page:   [1]
Honda Accord Forums >> General >> Do-It-Yourself Section
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
sir_nasty6303
wheelbrokera6276
falkore244355
00accordlx5s3708
deserthonda3500
19accord973013
jimblake2881
smaglik2504
rtexasf2282
yeuemmaimai1822
New Vendors
K&N Engineering, Inc.
