Headlight Clean Up...
Login | |
RE: Headlight Clean Up... - 10/16/2007 4:45:46 AM
RTexasF
Forum Monitor Posts: 2347
Joined: 11/16/2004 From: Brownsville, TX Status: offline
I use a plastic cleaner/polish and a buffer to get good results. Go for it and try the stuff but keep the receipt. If it doesn't cut it (pun intended) then take it back to Wally.
_____________________________
''''04 2.4l 5M EX Sedan Neuspeed short shift kit V-6 6 speed front strut/firewall brace 17mm rear anti sway bar AEM Shorty DC Sports SS Header Kicker Speakers JL Audio Clean Sweep JL Audio Amp 200W Bazooka sub V-6 OEM 7 spoke alloys
RE: Headlight Clean Up... - 10/17/2007 10:35:51 PM
ckebottle
Let me know how it works please. I have also wondered what you have.
99 accord ex 4cyl 4dr at 95 mercury grand marquis
RE: Headlight Clean Up... - 10/18/2007 4:58:14 AM
falkore24
I use claybar. works like a charm.
RE: Headlight Clean Up... - 10/18/2007 10:47:19 PM
Velocifero
quote:
ORIGINAL: falkore24 I use claybar. works like a charm. o rly? better than wet sanding? ive been meaning to do my sisters elantra. can you describe this my furry little friend?
CD5Tuner.com - 5th Generation Accord Online Community 94 Accord Mugen SiR Sports Sedan
RE: Headlight Clean Up... - 10/19/2007 8:33:18 AM
RTexasF
Clay has worked for me only sometimes. Consequently I don't waste time with it now and go direct to the plastic polish and buffer. Don't forget that the lenses must be protected afterwards. I use Aerospace 303 for that.
RE: Headlight Clean Up... - 10/19/2007 8:34:41 AM
RTexasF
quote:
ORIGINAL: Velocifero quote:
ORIGINAL: falkore24 I use claybar. works like a charm. o rly? better than wet sanding? ive been meaning to do my sisters elantra. can you describe this my furry little friend? Not furry but here's what he's referring to: http://www.autogeek.net/clbaandlu.html?gclid=CKS_ib6km48CFQ2aOAod80WgfQ
RE: Headlight Clean Up... - 10/19/2007 9:42:54 AM
falkore24
I use clay on everything!!!! Using 2 bars at a time makes it a lot easier to handle since if you drop it, it's garbage. I don't do the paint so much since it's not good to continuously strip the clearcoat, but for glass and plastic, I use it whenever I think it could get a little cleaner. It's essentially the same effect as wet sanding, but the clay is much more mild and you do it by hand. I use the cheapest spray detailer (currently Strauss brand) available as a lubricant and you use a lot of it. The area to be clay'd has to be WET with detail spray. You simply rub lightly and quickly with the clay until you dont hear it rubbing anymore. FYI ---- in real life, I'm not as fury as my avitar .... or my brother for that matter.
< Message edited by falkore24 -- 10/19/2007 9:45:00 AM >
RE: Headlight Clean Up... - 10/20/2007 10:04:03 AM
ckebottle
Thanks for that tid bit of info. Never thought to use a clay bar on glass and plastics. I'll have to pick some up and try it out!
RE: Headlight Clean Up... - 11/4/2007 7:24:02 PM
j_man_honda
Joined: 1/8/2007 From: South Carolina Status: offline
I wet sand with 320 grit SP, then with 800 git SP, then spray 3 coats of clear coat on the headlights....... We do this to almost every car at the car lot I work at.
1999 Honda Accord "EX"(SOLD) 1996 Nissan 240sx "SE"
RE: Headlight Clean Up... - 11/5/2007 8:23:53 AM
jbm07accord
I used some Headlight Restorer from AutoZone (I think Crystal View is the brand) on my wife's 99 civic. It fully restored the headlights and they are clear as new. Before they were discolored, cloudy, and dingy looking. Polishing would help but only for a short time. I think the stuff I bought was guaranteed for the life of the car. It was about $20, recommended to me by a friend, and I couldnt be happier. One thing to watch for is make sure you dont scuff the paint while you are sanding the headlight.
2oo7 Honda Accord EX-L 2dr V6 6-Speed
RE: Headlight Clean Up... - 12/3/2007 5:18:23 PM
bettner12
the walmart kit works wonders, the plastic on my bike was all yellow and cracked and about 30 min later it's crystal clear with just a little reading comprehesion and elbow grease. it's a heck of alot cheaper than a new headlight assy
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
