Help! Snapped off valve cover bolt
  Printable Version
Honda Accord >> Your Ride >> Engine & Internal >> Help! Snapped off valve cover bolt Page: [1]
Login
Help! Snapped off valve cover bolt - 8/21/2008 2:39:25 PM
adrian750
Status: offline
Being the genius that I am, I decided "one more good pull" was a great idea when tightening the valve cover bolts after changing the valve cover gasket. Snapped one of the bolts.
Any suggestions on how to get the bolt out and replace it? ''''92 Accord EX. The shop wants about $150 to fix, not covering gasket replacement which I can do.. well maybe I shouldn''''t on second thought.
Also, before this mistake, the car was overheating within a few minutes of startup everytime, but the coolant resevoir was always full with new fluid and I didn''''t see any leaks. Any ideas? Is this typical of a bad water pump? If so, how do I find out for sure and how difficult to replace?
Appreciate the help!
Post #: 1
RE: Help! Snapped off valve cover bolt - 8/21/2008 2:48:04 PM
JimBlake
Status: offline
Full reservoir doesnt really prove the actual radiator is full.  Open the cap (not when its hot).
It could be a bad thermostat, plugged radiator, or even a bad temperature gauge sender.  Gotta do some testing before you go out to buy a new waterpump.
_____________________________
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to adrian750)
Post #: 2
RE: Help! Snapped off valve cover bolt - 8/21/2008 4:08:52 PM
Hobbin
Status: offline
Sounds like you just snapped the head off the bolt? You''ll have to get a special drill bit. You''ll drill down through the bolt a little bit, then the "screw" part of the drill bit will catch hold and unscrew it out.
Dont tighten the COMPLETE bejesus out of bolts...they are strong
If you plan on being original, plan on being copied
Owner of "The Battleship"
NGK iridiums, Struts, Sways & tie brace, CAI, AND A NEW BATTERY
+nice deck && subwoof+speakers+2amps
quote:
ORIGINAL: finch13
I don''t know what Hobbin is smoki
(in reply to JimBlake)
Post #: 3
RE: Help! Snapped off valve cover bolt - 8/22/2008 6:26:06 AM
Fenix
Status: offline
Fenix's photo gallery
Yea drilling the bolt out is the option there, its what the dealership/garage is going to do anyway. If you dont know how to do it, or are uncomfortable doing it find a friend that has done it before. Thats what i had to do when i couldnt get a sensor off of my old intake manifold.
04 EX 4cyl 5AT Coupe
Fujita CAI
Custom Heads & TYC Tails
Apexi WS2 Cat Back Exhaust
Front Grill
Interior LED rods(7color)
20% Tint
TSX Intake Manifold
DC Ceramic Header
Ralco Light Weight Pullies(In Hand)
(in reply to Hobbin)
Post #: 4
RE: Help! Snapped off valve cover bolt - 8/22/2008 9:29:55 AM
klrspz
Status: offline
klrspz's photo gallery
careful not to tear up the threads either when pulling it out... you''ll then have to die-cut the bazza afterwords otherwise... and those tools aren''t cheap!
Silver '03 Honda Accord LX i4
My Car
Accord Link Collection
Wiki I'm Starting - http://hondaaccord.wikidot.com
(in reply to Fenix)
Post #: 5
RE: Help! Snapped off valve cover bolt - 8/22/2008 9:30:47 AM
klrspz
Status: offline
did i say that right? die-cut? i can''t remember the real term.. but i''ve done it before on some threaded stuff and it hurt my wallet pretty bad at the time (like $75 per set)
My Car
(in reply to klrspz)
Post #: 6
RE: Help! Snapped off valve cover bolt - 8/22/2008 9:55:32 AM
clutch811
Status: offline
ive done the gasket replacement a couple times and you do not need to tighten the crap out of the bolts. as long as you eat it right and use the honda bond or whatever at the corners you only need like 6 ft/lbs of torque on those bolts or so. the guy who had the car before me mustve tightened the crap out of it because the gasket was mashed and was leaking oil.
1994 Accord LX lowered
AEM short ram intake
megan header
Ractive cat back
Post #: 7
RE: Help! Snapped off valve cover bolt - 8/22/2008 10:55:25 AM
JimBlake
Status: offline
The gasket sits trapped in a groove, so the metal on either side of the groove comes down to contact the head.  Once that contact is established, any further tightening does NOTHING to improve the seal.
O-rings do not seal better when theyre mashed & flattened out.
(in reply to clutch811)
Post #: 8
RE: Help! Snapped off valve cover bolt - 8/22/2008 2:55:46 PM
poolman
Status: offline
If any part of the bolt is sticking up cut a slot in the top with a hacksaw or dremel tool.  If there is enough sticking up you could use some vise grips.  If it is broken off flush then use an EZ-Out.
Post #: 9
RE: Help! Snapped off valve cover bolt - 8/22/2008 3:33:47 PM
JimBlake
Status: offline
Left-handed drill bits actually do exist, but hard to find.  They often grab the broken bolt & spin it out as you drill the hole for the EZ-out.
(in reply to poolman)
Post #: 10
RE: Help! Snapped off valve cover bolt - 8/22/2008 9:15:03 PM
blinkz0rz
Status: offline
I''m in the same boat dude. Honestly, you can drive with it how it is for awhile. Just check the oil and make sure it isn''t leaking/spraying all over inside the hood. Until winter comes, you should be ok doing this.
But for fixing it, you will have to drill the broken acorn stud piece out of the head.
02 Accord SE coupe
F23A1
SRI
Post #: 11
RE: Help! Snapped off valve cover bolt - 8/26/2008 11:11:10 AM
pshepard8
Status: offline
I snapped two of mine off when I did the motor swap a couple of months ago.  If/when you take the valve cover back off, you should just be able to grab what''s left of the stud and screw it out.  If you''re not going to take it back off then you''ll want to get an easy out.  You drill a small hole in it, tap the easy out into the hole you drilled and then spin it out that way.  It''s actually an easy fix.
(in reply to blinkz0rz)
Post #: 12
RE: Help! Snapped off valve cover bolt - 8/30/2008 4:17:20 AM
kendo
Status: offline
you gotta use a drill to make a small hole in the bolt then use a easy-out bit to take it out,sears hase them
stay healthy,drink your veggie''''s
(in reply to pshepard8)
Post #: 13
Page:   [1]
Honda Accord Forum >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6841
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2649
smaglik2594
New Vendors
Sportwing
