High wattage bulbs
  Printable Version
Honda Accord Forum >> Your Ride >> Appearance >> High wattage bulbs Page: [1]
Login
High wattage bulbs - 4/19/2005 3:17:06 PM
Landscape Architect
Status: offline
Is anyone running higher wattage bulbs in there cars?
I want to put higher wattage bulbs in the high beams, but I'm concerned with wire size and the heat on the case/housing.
_____________________________
2002 Honda Accord LX (daily car)
1995 Mazda Miata (toy)
Post #: 1
RE: High wattage bulbs - 4/21/2005 1:05:59 AM
csofiarwaplau_85
Status: offline
I got both fog light and headlight of 8000k check it out, if you are interested, we could negotiate ( my car is the 2004 accord coupe)
http://www.autoshow.permaisuri.com/Content/Autoshow.asp?AutoID=20050204055009
(in reply to Landscape Architect)
Post #: 2
RE: High wattage bulbs - 4/21/2005 5:50:45 PM
Patrick
Status: offline
8000k are not higher wattage...8000k means that the filament temperature of 8000 degrees kelvin. it has nothing to do with wattage...however, an 8000k bulb is generally brighter than, say, a 4000k bulb..if you go to a true higher wattage bulb, going to high will draw too much power current flow through the wires,a nd melt them, and can often cause fire.
i wanted blinding foglights, so i adapted my foglight holders to allow me to put a low beam bulb in my foglights... it does get a big warm in there..but i have taken them apart, and inspected them, as well as drilled tiny holes along the top back to vent heat.
by the way..the black coupe looks Great!
< Message edited by Patrick -- 4/21/2005 5:51:58 PM >
(in reply to csofiarwaplau_85)
Post #: 3
RE: High wattage bulbs - 4/26/2005 2:04:10 PM
DCAaccord
Status: offline
why do you want higher watts?? for more brightness?? if you dont have xenons, then get those, they are must brighter then reagual halogen bulbs. make sure when u insall them you dont touch the bulb with ur hands, oil will make the bulb blow.
Remington870_20ga and DCAaccord,your forum audio gurus
--Shaved 99 Ex---
B16a Motor w/ Spoon Cams & Gears
Spoon Electronics & Suspension
Greddy Evo 2 Exhaust w/ Spoon Headers
(in reply to Patrick)
Post #: 4
RE: High wattage bulbs - 4/28/2005 12:31:37 PM
Landscape Architect
Status: offline
Yes, I'm looking for more light output, mainly on the high beams. I have 100 watt high beams in my miata (along with dedicated wiring/relays) and I miss the additional light output when I'm in the honda. I was just a little concerned about how well the housing would handle the additional heat.
I tend to lean towards halogen and "yellowstar"/all weather type bulbs that are more yellow in colour. For some reason, I have a harder time seeing with the Xenon bulbs that tend to be a little more blue. My eyes don't seem to process the bluer light colors very well at night.
(in reply to DCAaccord)
Post #: 5
RE: High wattage bulbs - 4/29/2005 3:56:06 PM
6thgen
Status: offline
6thgen's photo gallery
I say go with Sylvania or leave it alone, high wattages just suck up power. My blinkers turned into hyper blinkers when I put in Nokya, I re-installed Silverstars and whatta u know, it blinked normally again, plus the car stopped dying, from leaving the lights on for more than a min or two.
The car is looking for a turbine...
Post #: 6
Page:   [1]
Honda Accord >> Your Ride >> Appearance
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2649
smaglik2594
New Vendors
Sportwing
