Highest Kalven without kit?
  Printable Version
Honda Accord Forums >> Your Ride >> Appearance >> Highest Kalven without kit? Page: [1]
Login
Highest Kalven without kit? - 1/28/2008 4:54:28 AM
Yorty
Status: offline
Can you get a high kelvin bulb, or is over like 5000k require you to install a new conversion kit. I searched around and couldent find any topics already started on how high a bulb can go kelvin without any install or kit.
< Message edited by Yorty -- 1/28/2008 5:26:22 AM >
_____________________________
2005 Honda Accord EX Coupe Blue
AEM v2
Verge Caos Wheels
2007 Mercedes-Benz E320 BlueTec
3.0-liter turbo-diesel V-6
Post #: 1
RE: Highest Kalven without kit? - 1/28/2008 5:22:38 AM
BlkCurrantKord
Status: offline
BlkCurrantKord's photo gallery
Its kelvin, and you can buy bulbs that give the appearance of up to like 8000k. I have 6000k bulbs in mine. Ideally 4300k is the best.
Accord Mafia Member #001
(in reply to Yorty)
Post #: 2
RE: Highest Kalven without kit? - 1/28/2008 5:27:42 AM
Yorty
Status: offline
Yea sorry wrote from my phone, was in class. The 8000k can actualy produce enouf power?
AEM v2
Verge Caos Wheels
(in reply to BlkCurrantKord)
Post #: 3
RE: Highest Kalven without kit? - 1/28/2008 7:11:42 AM
Status: offline
quote:
ORIGINAL: Yorty
Hi Yorty..was that a question up above or were you giving us an answer to your own question
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
(in reply to Yorty)
Post #: 4
RE: Highest Kalven without kit? - 1/28/2008 8:24:02 AM
BlkCurrantKord
Status: offline
quote:
ORIGINAL: Yorty
The lower the number, the whiter to yellower it becomes.
4300k is almost pure white or close...the higher it gets the more purple/blue it becomes and actually emits less white light. Anything under 4300k would be good as a fog light.
(in reply to Yorty)
Post #: 5
RE: Highest Kalven without kit? - 1/29/2008 5:23:23 AM
AccordEXxx
Status: offline
If your talking about halogen bulbs than be prepared to lose your visability! Ive read the best after market ones htat are actually bright would be the silverstar ultras. Most of the other bulbs will look cool but they will decrease your light output. I conpared the stock 9006 bulb on one side and on the other i used a 9005 bulb (mod) and the stock ones were WAY brighter. hoped this helped
[2004 Honda Accord Coupe EX 5MT 108 000 KM]
Post #: 6
RE: Highest Kalven without kit? - 1/29/2008 12:08:40 PM
falkore24
Status: offline
falkore24's photo gallery
Kelvin on a light bulb is the COLOR temperature.  It has nothing to do with HEAT temperature, therefore if you can find it, you can use whatever ####(#)deg K bulb that you want.  As noted above, the closer to white that you get, the more efficient the bulb will be at producing light from the same input power (55 Watts for stock 9006).  Feel free to search Wikipedia for more info on this topic ..... or HAF also since this has been covered extensively numerous times.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to AccordEXxx)
Post #: 7
RE: Highest Kalven without kit? - 1/29/2008 12:13:44 PM
falkore24
Status: offline
quote:
ORIGINAL: AccordEXxx
9005 is a 65 Watt highbeam.  9006 is a 55 Watt lowbeam.  The number represents the socket; nothing else.  If you really did stuff 9005's into your lowbeam fixtures, you either irreversibly modified the plug or cut it off.  I highly reccommend that this is not done.  If you want more wattage, get a relay kit and high wattage bulbs.  Before my projectors, I had 80 Watt 9006 lowbeams and 100W 9005 highbeams.  They were definately brighter than OEM, silverstars, PIAA's (OEM Wattage) or any other normal power bulbs.
2000 V6-AT (RIP 3G)
Post #: 8
RE: Highest Kalven without kit? - 1/29/2008 3:05:49 PM
AccordEXxx
Status: offline
quote:
ORIGINAL: falkore24
Yeah how long did it take for your harness to melt. The 9005 mod to fit in a 9006 socket is a mod many people do. It is a bit brighter than 9006's but you can barely tell the difference.
(in reply to falkore24)
Post #: 9
RE: Highest Kalven without kit? - 1/29/2008 3:24:27 PM
falkore24
Status: offline
Note the high power relay kit.  Harnesses were fine because ceramic doesn't melt
The 9005 is brighter because it's normally 10 Watts more powerful.  For less effort, just go for the full high wattage system that I had.  It's not that expensive either..... maybe 50 bucks for the kit then new bulbs.
EDIT:  Technically, the high power bulbs are legal for offroad and show use only ..... they are still lower profile than blue/purple HID's
< Message edited by falkore24 -- 1/29/2008 3:28:21 PM >
2000 V6-AT (RIP 3G)
Post #: 10
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6759
sir_nasty6303
falkore245542
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3079
finch132990
smaglik2594
live2rice2391
New Vendors
Sportwing
