Hydraulic Clutch Problem
Login | |
RE: Hydraulic Clutch Problem - 8/9/2008 5:29:40 PM
PAhonda
There are two hydraulic cylinders for the clutch. The master cylinder is on the firewall, and the slave cylinder is near the front of the car, on the tranny, near the radiator. Are you losing any fluid?
_____________________________
1995 Accord EX MT
RE: Hydraulic Clutch Problem - 8/11/2008 7:29:40 AM
JimBlake
If the reservoir was empty, its not enough just to fill it. You have to bleed the clutch.
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
RE: Hydraulic Clutch Problem - 8/12/2008 11:28:43 PM
JimBlake
Thats strange. Still, you may have air in the system & need to bleed it.
RE: Hydraulic Clutch Problem - 8/13/2008 6:03:53 AM
rhobere
You probably have an air pocket in your master cylinder or something. You should just flush your clutch fluid.
RE: Hydraulic Clutch Problem - 8/13/2008 8:15:27 PM
Calm_B4_Chaos
Hey guys thanks.... I will have to bleed it out this weekend and tell you if that fixes it or not... thanks for the replies guys!
-- Calm B4 Chaos -- 1996 Honda Accord LS (2.2) F22B2 <~~ :( (4-Door) (5-Speed)
RE: Hydraulic Clutch Problem - 8/13/2008 8:50:52 PM
JimBlake
Clutch bleeding tricks... If you have a pressure bleeder, bleed it backwards. Suck out the reservoir fluid, then push fluid IN thru the bleed screw at the slave cylinder. That way you push the bubbles UPHILL, the way they naturally want to go. Old-fashioned bleeding? Tie a string around the clutch pedal. After you let the pressure out, the pedal wont spring back up - you have to pull it. Control it with foot, dont let it SNAP back up.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
