I need help swapping F23A1 into 94 accord ex
  Printable Version
Honda Accord >> Your Ride >> Engine & Internal >> I need help swapping F23A1 into 94 accord ex Page: [1]
Login
I need help swapping F23A1 into 94 accord ex - 6/25/2008 7:52:46 PM
VTEC!MASTER
Status: offline
Hello all,
I have a 1994 Honda Accord EX sedan with a F22B1 vtec 5-speed with 123k.  The current engine is burning alot of oil and has killed my gas mileage.  I have located a 2.3L F23A1 vtec from a 1998 Accord LX with 78k on it at a local junkyard for 300$.  I would like to do the swap but  am unsure about any  problems/complications.  Is this a bolt on swap?? or is there any modification needed??  I searched the forum but couldn''''t find any past talk of this particular application.  I really don''''t have any idea about the compatability of this swap, so any input/experienc/advice is greatly appreciated.    Thank You!!
< Message edited by VTEC!MASTER -- 6/27/2008 5:17:08 AM >
Post #: 1
RE: I need help swapping F23A1 into 94 accord ex - 8/21/2008 10:17:29 PM
Hobbin
Status: offline
Is it worth all the money and time?
I''d just fix up the engine you have. Put in new seals, clean it out, replace what''s necessary.
_____________________________
If you plan on being original, plan on being copied
Owner of "The Battleship"
NGK iridiums, Struts, Sways & tie brace, CAI, AND A NEW BATTERY
+nice deck && subwoof+speakers+2amps
quote:
ORIGINAL: finch13
I don''t know what Hobbin is smoki
(in reply to VTEC!MASTER)
Post #: 2
RE: I need help swapping F23A1 into 94 accord ex - 8/22/2008 9:27:27 PM
blinkz0rz
Status: offline
I can''t be 100% honest, but if the bellhousing matches up to the transmission you should be fine. Just make sure it uses the same motor mounts too.
The biggest problem will be the wiring.
02 Accord SE coupe
F23A1
SRI
(in reply to Hobbin)
Post #: 3
RE: I need help swapping F23A1 into 94 accord ex - 8/28/2008 9:24:32 AM
VTEC!MASTER
Status: offline
Hey, thanks for the input. I have since scrapped the swap idea, and decided to pull the head and replace valve guide seals and all other seals/gaskets that come in a head gasket set.  My engine has perfect/even compression across all 4 cylinders.  So i think the problem is in the top end...
1994 Honda Accord EX 4-door
2.2L F22b1 SOHC VTEC l4
CAI, NGK High-Performance Plugs/Wires, Performance Cat, Bose stereo
(in reply to blinkz0rz)
Post #: 4
Page:   [1]
Honda Accord Forum >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2649
smaglik2594
New Vendors
Sportwing
