If You Engine Stumbles On Acceleration?
  Printable Version
Honda Accord Forum >> Your Ride >> Engine & Internal >> If You Engine Stumbles On Acceleration? Page: [1] 2   next >   >>
Login
If You Engine Stumbles On Acceleration? - 8/30/2004 1:12:52 PM
Status: online
Then What May Be The Cause?
I'll start the forum with a Question and we shall see what kind of answers we will get.
This is not ment to make someone feel dumb, but is being started to HELP some one out there with any problems they may be running into with they're Honda Cars:
Yes I am ASE Certified and Have been licensed since 1989 by ASE so I do have a lot of the answers and they will be correct.
Later:
_____________________________
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
Post #: 1
RE: If You Engine Stumbles On Acceleration? - 8/30/2004 3:52:25 PM
maxst2
Status: offline
Timing, bad gas, dirty injectors, plugs bad or wrong gap, fuel filter needs cleaned/replaced...uhh...clutch majorly slipping. Detonation could cause it maybe..i'll never have the setup or power to really do that bad enough.lol
(in reply to WheelBrokerAng)
Post #: 2
RE: If You Engine Stumbles On Acceleration? - 8/31/2004 2:56:47 AM
Status: online
Let's see here...
MAXST2 has hit on the following answers to my question...
#1 spark plugs fouled or (electrodes worn out) in too many miles..Good*
#2 Dirty fuel injectors that may need replaced ..Good*
#3 Fuel Filter needs replaced (clogged) ..Good*
And here are two others that can be wrong with the situation...
#4 Incorrect Ignition Timeing
#5 Intake Manifold Air Leak (hard to find , but easy to hear)...
I will put in another Question session if any one liked this one..
Please let me know if this was liked and I will continue..
Thanks and Later...
(in reply to maxst2)
Post #: 3
RE: If You Engine Stumbles On Acceleration? - 11/13/2004 10:43:06 AM
PREDATOR
Status: offline
Could be a bad fuel pump too! Can't keep up in the higher RPM's
Post #: 4
RE: If You Engine Stumbles On Acceleration? - 11/19/2004 11:16:48 PM
poff1986
Status: offline
poff1986's photo gallery
hmm mixing of diesel fuel with regular! lmao
SOHC VTEC
(in reply to PREDATOR)
Post #: 5
RE: If You Engine Stumbles On Acceleration? - 11/22/2004 9:28:40 PM
Status: online
Hmmmmm! I think you've hit on the correct answer there poff...
I tried it and it really wasn't very good at all..But!!!
Carrot Juice and the Diesel taste GGGgggggggggeat
Thumbnail Image
Attachment (1)
(in reply to poff1986)
Post #: 6
RE: If You Engine Stumbles On Acceleration? - 11/22/2004 10:00:35 PM
poff1986
Status: offline
hmm nice..sounds really nutrucious! lol
SOHC VTEC
Post #: 7
RE: If You Engine Stumbles On Acceleration? - 12/17/2004 1:18:01 PM
ElectricTwilight
Status: offline
I know that for my year ('93) Honda released a bulliten that the lil plugs on the top of the intake manifold can get dirty and essentially screw up the airflow and i replaced them because mine was being twitchy on acceleration thru 3rd and it definitly helped the problem..but thats just my own special case
Post #: 8
RE: If You Engine Stumbles On Acceleration? - 1/15/2005 3:59:26 PM
bonylad
Status: offline
EGR.
(in reply to ElectricTwilight)
Post #: 9
RE: If You Engine Stumbles On Acceleration? - 1/17/2005 1:35:40 AM
Status: online
Hello Boneylad...Is this your final answer???/
Here all all the main answers to my question...
#1 Spark Plugs Fouled
#2 Fuel Injector System Is Faulty
#3 Fuel Filter Is Clogged (too many Big Mac's)
#4 Incorrect Ignition Timing
#5 Intake Manifold Has An Air Leak
Of course I can back this up with furthur diagonostic wording such as #1 Check your spark plug gap 0.039 to 0.043 inch--Spark Plug Wire Resistence: Less than 25000 ohms--Ignition Timing 15+/-2 degrees and on your 4 cyl : Engine firing order 1-3-4-2 distributor rotates clock wise...
More information will be posted on the next 4 #'s for you if you'd like...I'd be Happy to Teach as I am also Happy to learn from you members...
If your enjoying this form ...please let me know and I will continue on
(in reply to bonylad)
Post #: 10
RE: If You Engine Stumbles On Acceleration? - 2/3/2005 12:45:31 PM
bonylad
Status: offline
Hi. Any codes set? CEL on? If the engine is misfiring, as you reply suggests with fouled plugs and the other answers, the computer will cause a DTC for either random cylinder misfire OR cylinder misfire on 1,2,3, or 4. The fuel filter will cause another code, usually a/f too rich or too lean. An intake manifold leak will ususally present itself as a erratic or jumping idle.
Shoot me some codes, and I will pull out the shop manuals. I work for Honda so maybe I can help!
Post #: 11
RE: If You Engine Stumbles On Acceleration? - 2/10/2005 2:20:24 AM
Status: online
How about that code 1457 that was in the other forum...
What does that one mean boneylad?
Post #: 12
RE: If You Engine Stumbles On Acceleration? - 3/1/2005 1:29:03 AM
Status: online
Hey BonyLad...are you still with us?? and did you ever find out what that code was?
quote:
ORIGINAL: WheelBrokerAng
Post #: 13
RE: If You Engine Stumbles On Acceleration? - 3/1/2006 6:24:13 AM
darryltravis
Status: offline
Hello Wheel, I need some help really bad.....my 93 accord LX instrument cluster is acting crazy. First the speedo started acting irratic, sometimes it will register right and other times it goes to 35mph and stays there. At idle, the speedo sometimes will slowly creep down to about 12mph.....now the fuel gauge is acting stupid. Could you help me please. My personal email is darryl.travis@eustis.army.mil
Thank you
Post #: 14
RE: If You Engine Stumbles On Acceleration? - 3/1/2006 10:04:05 AM
mbo1985
Status: offline
That's how my speed sensor acted before it quit on me. It could be that. But if the fuel gauge is acting up, it could be the cluster I guess... unless the sending unit is scewing up too.
(in reply to darryltravis)
Post #: 15
Honda Accord >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6841
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2649
smaglik2594
New Vendors
Sportwing
