Ignition coil
  Printable Version
Honda Accord >> Your Ride >> Engine & Internal >> Ignition coil Page: [1]
Login
Ignition coil - 7/14/2008 4:40:25 PM
FlyLow
Status: offline
Is it necessary to replace the ignition coil (the one under distributor cap) after a certain time? Does the tip wear out? Or is there a way to clean the tip with something?
2dr 1999 Accord LX 2.3L 5-spd
Post #: 1
RE: Ignition coil - 7/15/2008 6:13:35 AM
JimBlake
Status: offline
No schedule for replacement.  Wait till it breaks.
I usually scrape the crud out with a knife.  Theres no motion against that, so it usually doesn''t get bad.  Is it missing the little spring so the spark has to jump a gap??
_____________________________
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to FlyLow)
Post #: 2
RE: Ignition coil - 7/15/2008 6:07:28 PM
FlyLow
Status: offline
If you mean the spring on the distributor cap that is supposed to touch the coil tip, then yes it is there. The tip looks delicate i was affraid to scrape it off. What does it look like when new? Any one have a picture?
(in reply to JimBlake)
Post #: 3
RE: Ignition coil - 7/16/2008 6:33:25 AM
JimBlake
Status: offline
Coil #11 isnt shown in much detail.
Post #: 4
RE: Ignition coil - 7/20/2008 4:36:27 PM
FlyLow
Status: offline
so I just changed the distributor cap and the rotor. I put a bunch of dielectric grease on wires and caps connectors. The car started for a few seconds just fine, and then died, and now it wont start.  What the happened? (same car as above)
Post #: 5
RE: Ignition coil - 7/20/2008 5:49:10 PM
FlyLow
Status: offline
Turns out the fuel pump isnt working, cause i cant hear it when ignition is turned on, the fuse looks fine.  How does the pump go out from changing distributor cap and rotor?
Post #: 6
RE: Ignition coil - 7/20/2008 6:42:21 PM
FlyLow
Status: offline
The manual says to test the lead #5 on connector that is on the fuel pump for voltage.  Is that with ingnition on or off?  I didn''t get voltage from there.  Has anyone had this problem?
Post #: 7
RE: Ignition coil - 7/20/2008 7:29:18 PM
FlyLow
Status: offline
Car has 110K miles, how long do fuel pumps last?
Post #: 8
RE: Ignition coil - 7/21/2008 7:34:26 AM
JimBlake
Status: offline
Turn key to ON but not immediately to START.
Main relay gives power to fuelpump for about 2 seconds.  Test that wire during that time.
Post #: 9
RE: Ignition coil - 7/21/2008 2:35:30 PM
FlyLow
Status: offline
Ok I got roughly 12V on one of the leads  for about 2 seconds, on the fuel pump connector, after turning the ignition to ON, just before start.  So it has to be the fuel pump.  Is there a way to test the pump without taking it out?
Post #: 10
RE: Ignition coil - 7/21/2008 3:18:20 PM
JimBlake
Status: offline
Test OTHER lead for good ground connection.
Then make up jumper wires to supply power (+ & -) dirctly from battery to pump.
If pump runs with the jumpers, we need more tests.
< Message edited by JimBlake -- 7/21/2008 3:26:06 PM >
Post #: 11
RE: Ignition coil - 7/21/2008 9:41:30 PM
FlyLow
Status: offline
I got a new pump from autozone $174 swapped it out, and she started right up.
Post #: 12
RE: Ignition coil - 7/22/2008 5:35:05 AM
JimBlake
Status: offline
Thanks for posting the FIX.  I would have tested before spending that much, but you got it done.
Post #: 13
Page:   [1]
Honda Accord Forum >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6580
sir_nasty6303
falkore245019
00accordlx5s3760
deserthonda3537
19accord973090
jimblake2934
smaglik2515
rtexasf2337
finch132151
New Vendors
Sportwing
