Leaking heater hose
Login | |
Leaking heater hose - 9/27/2008 4:59:04 PM
imjrk
''96 Accord, VTECH, auto: Replaced hoses when I replaced engine, BUT used the factory hose clamps. Of course, now one is leaking at the firewall. How do I get in there to replace the hose clamp? Looks to me like I would need to remove the upper intake manifold to have enough room to replace the hose clamps. Any better way, or do I need to take the manifold apart? Thanks
RE: Leaking heater hose - 9/27/2008 11:43:15 PM
deserthonda
wooooooo,,,,no need to take anything apart, you should be able to replace all the hoses without removing the manifold . if it is the hose at firewall, remove the air intake tube ,, that should give you planty of room to replace the clamp for the heater hose at firewall..... also, you do not have to take the hose off, just slide the clamp that is there now backwards on the hose and install a new hose clamp , the one that you spread open and tighten with a screwdriver .
_____________________________
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: Leaking heater hose - 9/28/2008 11:17:40 AM
imjrk
Thanks for the advice, have it fixed. Took some time to get in there, but I did get it. Thanks.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
