Question about '03 Accord Sedan
  Printable Version
Honda Accord >> Your Ride >> Tires & Wheels >> Question about '03 Accord Sedan Page: [1] 2   next >   >>
Login
Question about '03 Accord Sedan - 7/18/2006 11:25:57 AM
03Sleeper
Status: offline
03Sleeper's photo gallery
Would 225/50/R17 fit? The stock tires are 205/65/R15. My car is not lowered in any way, shape or form...so more tire space?
Thumbnail Image
Thumbnail Image
Attachment (2)
< Message edited by 03Sleeper -- 7/18/2006 11:26:52 AM >
_____________________________
2003 Accord LX Sedan I4| 5AT 101045
Injen SRI w/ AEM Dryflow| DCSports Ceramic Headers| DENSO IK20 Sparks| CF Front Strut Bar| Pioneer TSG950M 6x9s| Alpine SPS17C2 6.5"| C-Tek Slotted/Drilled Rotors | Progress 24mm Rear Sway Bar
Post #: 1
RE: Question about '03 Accord Sedan - 7/18/2006 11:51:25 AM
sir_nasty
Status: offline
those should fit providing you have a rim that is offset enough to keep it from rubbing on the inside when you turn.... I'd go to like www.1010tires.com and check out their plus sizing chart to determine what would be the best 17 to run, try to keep your outside diameter the same
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Quote: Life''s great but it''s not all beer and skittles
(in reply to 03Sleeper)
Post #: 2
RE: Question about '03 Accord Sedan - 7/18/2006 11:57:48 AM
03Sleeper
Status: offline
Seems I can do 235/40/R18
Thumbnail Image
Attachment (1)
< Message edited by 03Sleeper -- 7/18/2006 12:14:13 PM >
(in reply to sir_nasty)
Post #: 3
RE: Question about '03 Accord Sedan - 7/18/2006 1:04:40 PM
sir_nasty
Status: offline
keep in mind that bigger rims= more weight so you're going to drop some fuel economy and performance unless you can maintain a weight close to what you already have...
Post #: 4
RE: Question about '03 Accord Sedan - 7/18/2006 8:07:06 PM
03Sleeper
Status: offline
Crud...I was hoping I did not have to change my rims.
Confound it all.
Post #: 5
RE: Question about '03 Accord Sedan - 7/19/2006 7:39:07 AM
RTexasF
Forum Monitor
Status: offline
RTexasF's photo gallery
quote:
ORIGINAL: sir_nasty
That would also reduce braking performance by going to mongo size wheels.
''''04 2.4l 5M EX Sedan
Neuspeed short shift kit
V-6 6 speed front strut/firewall brace
17mm rear anti sway bar
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Clean Sweep
JL Audio Amp
200W Bazooka sub
V-6 OEM 7 spoke alloys
Post #: 6
RE: Question about '03 Accord Sedan - 7/19/2006 10:56:18 AM
03Sleeper
Status: offline
Hmm...looks like I'm goin for the 215/50R17 ones then.
(in reply to RTexasF)
Post #: 7
RE: Question about '03 Accord Sedan - 8/12/2006 2:30:50 AM
03Sleeper
Status: offline
http://cgi.ebay.com/ebaymotors/16-Inch-Wheels-Rims-Black-Honda-Civic-Accord-4-Lug-NEW_W0QQitemZ260017375522QQihZ016QQcategoryZ43957QQrdZ1QQcmdZViewItem
Would '02 Accord rims/tires fit on '03 Accord?
< Message edited by 03Sleeper -- 8/12/2006 2:36:42 AM >
Post #: 8
RE: Question about '03 Accord Sedan - 8/17/2006 1:46:16 AM
oldeskewltoy
Status: offline
Hmmm alloy wheel(especially some of these ultra minimalist types) verses rubber and belts and tall sidewalls... I beg to differ, a GOOD wheel in a larger size with a shorter side walled tire should NOT have more mass, then a smaller wheel with MORE tire.
Can I ask... why you want a wider tire? Is it just for the stance? If that is what you are after, then fit what you can... but for handling... you really want to match the tread to the cars handling capability. You could actually handle better with a superior compound in a slightly smaller tire then a cheap componud in ANY size tire... AND even handle better then the same superior tire in 2 sizes wider. The first part you can understand... superior rubber compounds , versus cheapo rubber compounds. What is more difficult to understand is why a 2 size wider tire of a similar compound would handle worse. This is simple really, it all has to do with HEAT, superior tires tend to work better when warm. a wider tire works less hard and in so doing... may not get as warm as it's thinner version. Corrallary - they will wear faster....
The Accord is no svelt everyday jogger... the Civic fits that bill better.... So I do like your idea of going one size wider 205 to 215, I also like the 16" wheels... costs go up exponentially as rim diameter increases, and side walls fall. Using calculations from tire calculators... the closest match would be 215/55/16. Spend the extra $$ you would on a 17" tire for a better 16" tire.
jmho........
I ran a tire size search at tire rack... there are a few tires in this group that are both affordable, and superior.
http://www.tirerack.com/tires/Compare1.jsp?width=215%2F&ratio=55&diameter=16&startIndex=0&search=true&pagelen=20&pagenum=1&pagemark=1&performance=EP&performance=MP&performance=UHP&performance=HP&performance=UHPAS&performance=HPAS&speed_rating=HR&speed_rating=VR&speed_rating=ZR&speed_rating=WR&speed_rating=YR&RunFlat=All&x=69&y=10
< Message edited by oldeskewltoy -- 8/17/2006 1:51:41 AM >
Post #: 9
RE: Question about '03 Accord Sedan - 8/24/2006 9:42:25 PM
03Sleeper
Status: offline
Thanks!
(in reply to oldeskewltoy)
Post #: 10
RE: Question about '03 Accord Sedan - 8/27/2006 12:45:12 AM
03Sleeper
Status: offline
Will these 17" rims fit?
http://cgi.ebay.com/ebaymotors/17-Rims-Black-Cooper-Civic-Scion-Lancer-4-Lug-Wheels_W0QQitemZ180022475322QQihZ008QQcategoryZ43957QQrdZ1QQcmdZViewItem
Post #: 11
RE: Question about '03 Accord Sedan - 9/1/2006 3:08:53 PM
03Sleeper
Status: offline
Yes...no? And I'm thinking of using stock size tires with 17"...bad idea?
Post #: 12
RE: Question about '03 Accord Sedan - 9/6/2006 7:15:56 PM
oldeskewltoy
Status: offline
sorry was away for a bit. I don't know what rim will fit... but Tire Rack does... besides selling tires, they also sell wheels. AND... they have a nifty wheel fitment guide that shows a side view of your car and how each of the wheels they offer fits. They will not offer a wheel that won't fit, so you can look at all their offerings. You DON'T have to buy there... although they are almost always the best price (unless you can score a set used...) but they are the best place to go first... see what you like, and then do some coparitive shopping once you know!
So concerning the wheel you posted... unless it is in the list at Tire Rack (or any other competent fiment guide), I'd just walk away.
I got the tires today(9/6/06) and will be mounting them either tonight, or tomorrow. review to follow!!!
Post #: 13
RE: Question about '03 Accord Sedan - 9/6/2006 7:31:12 PM
Yamaroket
Status: offline
I should be getting my wheels and tires tomorrow, I'll post some pics once I put them on
Post #: 14
RE: Question about '03 Accord Sedan - 4/1/2007 10:43:24 PM
03Sleeper
Status: offline
These will fit using stock tires right?
http://cgi.ebay.com/ebaymotors/Nippon-KG-5-Light-Wheels-17-Inch-Rims-5x114-3-Silver_W0QQitemZ230110081346QQcategoryZ43957QQrdZ1QQcmdZViewItem
(in reply to Yamaroket)
Post #: 15
Honda Accord Forum >> Your Ride >> Tires & Wheels
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6827
sir_nasty6303
falkore245650
00accordlx5s3797
deserthonda3574
finch133238
jimblake3131
19accord973125
live2rice2622
smaglik2594
New Vendors
Sportwing
