Rear Window Regulator TIPS & TRICKS
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> Rear Window Regulator TIPS & TRICKS Page: [1]
Login
Rear Window Regulator TIPS & TRICKS - 5/7/2006 4:17:12 PM
deserthonda
Score: 0
Status: offline
Ever have the rear window do not close all the way? leave about 1/4 to 3/4 inch gap ?? Want to save money ??
Well here is a trick you guys can try ..
I know it works on 90-93 accords have done it 2 times ,, And it should work on the 94-97 accords ..
you can solve this problem by drilling 3 new holes holes,straight up from the originals and raising the regulator
.you need to measure the open gap when the window is all the way up ,, i would then add about another 1/4 inch just to make sure the window will seal at the top.
So let's say the gap was 1/2 inch ,adding another 1/4 inch , you should mark and drill the holes 3/4 inch higher than where the mounting holes are now ,
where the regulators mounting holes are right now, mesure straight up and mark a spot adding the new measurement you took ,,
Drill three matching holes and bolt the regulator to those new holes .
Now keep in mind that when the window is all the way down it will stick up a bit more at the bottom , if you do not mind ... great ,,
but if you don't feel comfortable , you can always dish out the money and replace the regulator
I have done this a few times, on a couple of cars and it worked great
Hope this can help some of you save some money
Post #: 1
RE: Rear Window Regulator TIPS & TRICKS - 5/8/2006 7:31:57 AM
brad6841
Score: 0
Status: offline
That is a sweet cheap fix....
_____________________________
Brad
2002 Accord Coupe EX V6
(in reply to deserthonda)
Post #: 2
RE: Rear Window Regulator TIPS & TRICKS - 5/11/2006 1:33:54 AM
deuce2
Score: 0
Status: offline
great fix. thank you very much
Post #: 3
Page:   [1]
Honda Accord Forum >> General >> Do-It-Yourself Section
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6827
sir_nasty6303
falkore245646
00accordlx5s3797
deserthonda3574
finch133238
jimblake3131
19accord973125
live2rice2622
smaglik2594
New Vendors
Sportwing
