deserthonda
Score: 0 Joined: 12/3/2005 Status: offline
sorry that it took so long to give you a reply,,,,,,,,,, on the driver under dash fuse box chk fuse # 3 7.5 amps. if no good replace as needed .. on the underhood fuse box chk fuse # 53 40 amps .... If both fuses are ok,,, could be a bad rear window defogger relay. located in the passanger under dash fuse/relay box.
_____________________________
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
