Reset ECU
  Printable Version
Honda Accord Forum >> Your Ride >> Nitrous, Super Chargers, & Turbos >> Reset ECU Page: [1]
Login
Reset ECU - 6/23/2006 5:03:15 AM
Zambo
Status: offline
How do i reset my ECU would the best way to just take the battery terminal off or what or is their a propper reset switch ? Just out of curiosity cause i know a mate with a magna an he had to do it when he put his exausht and Cold Air Intake on?
Zambo
Post #: 1
RE: Reset ECU - 6/23/2006 11:36:14 AM
sir_nasty
Status: offline
I've always been under the impression that just pulling the negative battery terminal will do it...
_____________________________
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Quote: Life''s great but it''s not all beer and skittles
(in reply to Zambo)
Post #: 2
RE: Reset ECU - 6/23/2006 4:18:40 PM
Zambo
Status: offline
Same Here Thankyou ill give it ago
(in reply to Zambo)
Post #: 3
RE: Reset ECU - 6/23/2006 8:20:23 PM
mbo1985
Status: offline
For future reference, you can just pull the battery back up fuse (7.5 amp) for a minute or so. It's good for when you don't have tools at hand.
1996 Accord LX Coupe
Suspension Techniques Springs
KYB AGX Struts
Turbocharged
(in reply to Zambo)
Post #: 4
RE: Reset ECU - 8/13/2006 12:40:53 AM
9JordonFlex9
Status: offline
Simple enough, hopefully you see this....
This is how you do it...lil more than just pullin the negative off
Disconnect the negative battery part(whatever the tech term is...) , let it sit for at least 30 seconds...you can let it sit as long as you want, do so...I let mine sit for at least a decent 10minutes, overnight is good....
Turn on the car, let it run for 5-10minutes, dont touch the gas at all. (or whenever the fans turn on to cool the engine....)
Turn off the car.
Run it as you like then.
After you turn it off, if you have modifications, do it with each one so the ECU can adapt to each one....they suggest to do it with each weather change.....fall, winter, spring, summer, easy nuff
This can never hurt your ECU, most Honda dealerships do this when you bring it in for tune ups and whatnot
Dont reset ecu if ur running a different type of gas, or gas additives.
Hint-You can also(while the negative is off the battery) step on the brake for 10 seconds to help make sure the ECU is cleared and memory is cleared for the next turn of the key.
Also! If you do have mods, some people run it hard to get used to pushing itself to the limit, a good 3 runs, 1st through 3rd some people.
Hope that helps you out to the fullest
(in reply to mbo1985)
Post #: 5
Page:   [1]
Honda Accord >> Your Ride >> Nitrous, Super Chargers, & Turbos
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6827
sir_nasty6303
falkore245650
00accordlx5s3797
deserthonda3574
finch133238
jimblake3131
19accord973125
live2rice2623
smaglik2594
New Vendors
Sportwing
