Sheared Camshaft-Options?
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> DIY Requests >> Sheared Camshaft-Options? Page: [1]
Login
Sheared Camshaft-Options? - 4/23/2008 7:40:09 AM
abbiesdad
Score: 0
Status: offline
    I have a 94 Accord with a single overhead cam engine bought used that looks like it had some "work" done on the engine. While our nanny was driving it, it broke down on the highway. No noises were reported, just quit. Got it home and opened the hood. Noticed the timing belt cover was worn through and I could see the pulley on the end of the camshaft. Pulled back the cover and the gear on the end of the camshaft was sheared off. Not unbolted, sheared. I'm not at home now or I would take a picture.
My question is this. What are the chances that I could just replace the camshaft and have it work? Pretty slim I assume. I found a junkyard where I can get an engine for $450 with an exchange. Would that be a more reasonable idea? Also, a head replacement was suggested. I think I am leaning that way but I thought i would run it by the experts here to get some opinions.
I am fairly confident in my skills and I research very thoroughly before I start a project. In fact this question is the beginning of my research on this.
Post #: 1
RE: Sheared Camshaft-Options? - 4/23/2008 7:54:14 AM
white95
Score: 0
Status: offline
Probably ran out of oil.  You are going to have bent valves.  Replacing the head would not be much cheaper than replacing the motor.  Fixing the current motor would be more.  I suggest swapping the motor.
_____________________________
95 Honda Accord LX 5-speed
95 Dodge Dakota SLT 5-speed CC
97 Dodge Caravan
(in reply to abbiesdad)
Post #: 2
RE: Sheared Camshaft-Options? - 4/23/2008 7:55:55 AM
finch13
Score: 0
Status: offline
i think a sheared cam gear would carry the same effect as a broken timing belt would: bent valves and other damage to the head. A head swap would be easier and cheaper, but a whole engine swap is doable as well. I actually have a non-VTEC head for that motor if you want it... with upper timing belt cover.
-> USE ME TO SEARCH HAF <-
1999 Accord LX F23A1 5MT
Post #: 3
RE: Sheared Camshaft-Options? - 4/23/2008 9:27:45 AM
abbiesdad
Score: 0
Status: offline
That sounds like something that could happen. How much are you looking to get for it? Any idea how much shipping to Atlanta, GA would be?
Thanks for the replies, I appreciate it.
Terry Slate
(in reply to finch13)
Post #: 4
RE: Sheared Camshaft-Options? - 4/23/2008 9:36:58 AM
finch13
Score: 0
Status: offline
$200 Shipped. It doesn't have any bent valves or damage. Never blown a head gasket either. It does need to have the valve clearances adjusted, but that should be done on your engine.
Post #: 5
Page:   [1]
Honda Accord Forum >> General >> Do-It-Yourself Section >> DIY Requests
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6760
sir_nasty6303
falkore245542
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3079
finch132991
smaglik2594
live2rice2397
New Vendors
Sportwing
