Steering wheel shakes...
Login | |
Steering wheel shakes... - 6/12/2005 12:56:56 PM
Guest
Hi again... I've got a '94 Accord EX... when I get above 50 MPH my steering wheel shakes and the car pulls a little to the right.. Is this an alignment problem, or brake/bearing problem?? I have replaced both bearings, CV joints, rotors, brakes, and upgraded up to 16" wheels. I have not yet got an alignment... Thanks.
_____________________________
2006 Honda Accord EX-L Taffeta white K24 i-VTEC 1,xxx miles. Previous: 1996 Honda Accord EX-L custom white gold pearl w/ white leather interior F22 VTEC 167,000 miles
RE: Steering wheel shakes... - 9/5/2005 3:16:10 PM
RTexasF
Forum Monitor Posts: 2347
Joined: 11/16/2004 From: Brownsville, TX Status: offline
Have the wheels balanced and have it alligned is the way I would go.
< Message edited by RTexasF -- 9/6/2005 10:06:35 PM >
RE: Steering wheel shakes... - 7/3/2007 10:07:42 AM
bigkhaat
Is it still shaking after the repairs u listed..?
bigkhaat
RE: Steering wheel shakes... - 7/3/2007 12:11:19 PM
smaglik
Could be a bad belt it a tire too.
1987 BMW 635csi 5MT 1995 Honda Passport LX 4WD 6CYL 5MT
RE: Steering wheel shakes... - 7/5/2007 2:04:00 PM
Deuceswildt3
Mine does the same thing....you just need to have it alignment
Deuces....Deuces
RE: Steering wheel shakes... - 7/17/2007 9:10:15 AM
ohiostatepimp22
i have the exact same problem...its annoying...
RE: Steering wheel shakes... - 7/17/2007 9:40:13 AM
smaglik
wow. this thread is old. who revived it?
RE: Steering wheel shakes... - 7/20/2007 7:23:06 AM
finch13
I don't have the shaking problem so much, but after a full alignment my car still pulls slightly to the left. I hit a curb last winter, um sliding around corners :-), and ended up bending the LF lower control arm. I had to replace the lower control arm, lower ball joint, stabilizer link, and drive axle (bad CV joint, different story). Still after fixing it myself and then getting it aligned it still pulls. Could I have bent a tie rod in the steering or something. I know when I hit the curb I let go of the steering wheel to take stress off the steering system.... any ideas?
USE ME TO SEARCH HAF 99 Accord F23A1 5MT
RE: Steering wheel shakes... - 7/22/2007 8:39:15 AM
deserthonda
Finch,, the people that did the alignment by the readings they should know if there are any more damaged suspension parts.. if the alignment is all in specs ( toe, camber, caster) and car still pulls, switch the frt tires side to side and test drive it let us know
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: Steering wheel shakes... - 7/23/2007 1:06:34 PM
smaglik
quote:
ORIGINAL: finch13 I don't have the shaking problem so much, but after a full alignment my car still pulls slightly to the left. I hit a curb last winter, um sliding around corners :-), and ended up bending the LF lower control arm. I had to replace the lower control arm, lower ball joint, stabilizer link, and drive axle (bad CV joint, different story). Still after fixing it myself and then getting it aligned it still pulls. Could I have bent a tie rod in the steering or something. I know when I hit the curb I let go of the steering wheel to take stress off the steering system.... any ideas? did you try flipping the front tires? bad tire can cause it to pull.
