Stock alloys for my '05 sedan lx 4cyl....
  Printable Version
Honda Accord Forum >> Your Ride >> Tires & Wheels >> Stock alloys for my '05 sedan lx 4cyl.... Page: [1]
Login
Stock alloys for my '05 sedan lx 4cyl.... - 9/6/2005 8:38:45 PM
B8mn1
Status: offline
I am interested in some of the newer style 5 spoke stock alloys for my new accord.... will the 16" bolt on?? are there any larger "Honda" wheels??
Any recommendations for cool, inexpensive (less expensive) wheels / tires.. I was hoping to locate so new take-offs someone wants to dump....
Thanks, Ben
_____________________________
1980 Honda CBX 6 cylinder
1983 Honda CB1100F SuperSport
2005 Honda Accord LX 4cyl
Post #: 1
RE: Stock alloys for my '05 sedan lx 4cyl.... - 9/8/2005 2:35:02 AM
Status: offline
Hi New Member...
My question to you is this...you have a new 2005 Accord LX 4dr and you are looking for newer Alloy Honda Wheels 5 spoke...is this correct?
Maybe Like These?
Thumbnail Image
Attachment (1)
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
(in reply to B8mn1)
Post #: 2
RE: Stock alloys for my '05 sedan lx 4cyl.... - 9/8/2005 3:32:21 AM
B8mn1
Status: offline
My LX came with steel wheels and hub caps...
I would like to find some alloy wheels reasonable,,, I thought if someone had bought a new car and removed the wheels for 18" or so, maybe they would be interested in selling the stock alloys for a reasonable price....
Tha photo you posted is what I like.....
Got any?? are they cheap?
Thanks,
Ben
(in reply to WheelBrokerAng)
Post #: 3
RE: Stock alloys for my '05 sedan lx 4cyl.... - 9/16/2005 10:45:33 PM
B8mn1
Status: offline
Okay, I don't know if anyone is still looking at this thread, but......
I just found an ad for '05 acura TL 17" factory Alloy wheels and michelin pilot 235/45/17 tires,, less than 2k mikes, for $600.00... Does anyone know how they will fit my '05 accord lx ...... will they be too wide??? they are obviously 30mm wider than stock, but I'm not sure the offset... if they would stick out I'll pass,,,,
opinions???
Wheelbroker.. your thoughts??
Thanks,
Ben
(in reply to B8mn1)
Post #: 4
RE: Stock alloys for my '05 sedan lx 4cyl.... - 9/20/2005 11:11:03 PM
Status: offline
Hi sorry about the delay but I forgot about this thread...but here I am again..
The wheels from the 05" Acura TL and the 05 Accord are interchangeable , they are both the same bolt pattern and will fit both cars...
Here are two pictures of those wheels for you to check out...
Hope this is good for you....
Thumbnail Image
Thumbnail Image
Attachment (2)
(in reply to B8mn1)
Post #: 5
RE: Stock alloys for my '05 sedan lx 4cyl.... - 9/21/2005 12:44:28 AM
B8mn1
Status: offline
WheelBrokerAng,
I am really concerned about the tires fitting under the wheel wells... 235/45/17's are pretty wide, and it almost looks like the front fenders on an Acura are flaired more then the accord...if so, that would cause them to stick out....?? have any experience with this size wheel / tire on an accord???
Thanks for all you input...
Ben
Post #: 6
RE: Stock alloys for my '05 sedan lx 4cyl.... - 6/27/2006 11:02:15 PM
mamarotta
Status: offline
well hello all I have the same question... i am abou tot put on the same wheel on my 05 accord 4 cyl but i have ordered 245 45 17 tires. Ill post after I try this...to late but i couldnt wait anylonger so i went ahead to try it. if it doesnt work i have a prefectly good set of brand new wheels an tires...let u know soone enough.
(in reply to B8mn1)
Post #: 7
RE: Stock alloys for my '05 sedan lx 4cyl.... - 6/29/2006 12:23:56 AM
Status: offline
They will not fit your accord...the tires that is..the 235mm tires do fit the TL..
your 05' Accord takes a 215/50/17 tire which fits in there the correct way...
quote:
ORIGINAL: B8mn1
opinions???
Thanks,
Ben
(in reply to B8mn1)
Post #: 8
RE: Stock alloys for my '05 sedan lx 4cyl.... - 6/29/2006 12:50:02 AM
mamarotta
Status: offline
well accord to where i bought my wheels they fit the tl and accord...so then if that fits both then there is a possiblity that the 245 45 17 might fit if its a little wider
Post #: 9
RE: Stock alloys for my '05 sedan lx 4cyl.... - 7/4/2006 8:43:37 AM
mamarotta
Status: offline
tl wheels fit with slight rubbing on bumpy roads other wise just fine and look great....center caps next.
(in reply to mamarotta)
Post #: 10
RE: Stock alloys for my '05 sedan lx 4cyl.... - 7/4/2006 10:42:00 AM
Status: offline
Better get out the baseball bat and prepar to roll the front and rear fenders out about 1" to keep from cutting the rubber off the tires..
quote:
ORIGINAL: mamarotta
Post #: 11
RE: Stock alloys for my '05 sedan lx 4cyl.... - 7/6/2006 11:11:53 AM
mamarotta
Status: offline
k so how about this does anyone know if there are after market front fenders that are flaired just slightly more. that would take care fot he front. how about the the rears is there a kit that a good body shop might be able add and make the body flair wider in the back also?
Post #: 12
RE: Stock alloys for my '05 sedan lx 4cyl.... - 7/6/2006 11:25:46 PM
Status: offline
If you can Find a real body shop who has the expertise and it's in your area, then they can do anything you want if you have the cash-ola..Kits no matter what still, need to have that good body shop to hang them on also..
quote:
ORIGINAL: mamarotta
Post #: 13
RE: Stock alloys for my '05 sedan lx 4cyl.... - 11/3/2006 1:23:27 PM
vintageant
Status: offline
235 50 17 should work just fine as the diameter is 26.25" vs 25.69" for 205 60 16 (2.21% increase). The only issue I see is front tire rubbing on full lock.
2003 Accord EX I-4 5 speed 117K
Post #: 14
RE: Stock alloys for my '05 sedan lx 4cyl.... - 12/3/2006 7:43:13 PM
nmshhmx
Status: offline
Im new here and probably blowing it but here it goes???? Is there or will there be a problem if I put 16" wheels and michlean mxv 4 plus tires on a 2002 accord 4 dr??? Im confused I want the car to look good without loosing the ride...Im older guys so humor me please...thank you in advance
(in reply to B8mn1)
Post #: 15
Page:   [1]
Honda Accord >> Your Ride >> Tires & Wheels
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6760
sir_nasty6303
falkore245542
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3079
finch132991
smaglik2594
live2rice2397
New Vendors
Sportwing
